Sig Hummer
My Feedback: (197)
MN
Sig Hummer
I am getting a sig hummer going. I am going to use mini servos and a AAA size rx pack. Power will be a Norvel 049 RC.
Can anyone tell me the CG for this plane? ALso, what should I use for control throws on elev and ailerons? I would imagine 1/8" would be enough. I will not be using dual rates.
FL
RE: Sig Hummer
on the spar. 1/8" is ok to start, but you will want more as you get used to it. I had one with 4-channel, just hinged the rudder. but it knife edged funny; the angled rudder hinge line I used caused it to roll couple the wrong way; I had to hold rudder and aileron in the same direction in knife edge! would recommend changing rudder shape, if you need it to knife edge. a great flier. only other funny thing it did was sometimes it wouldn't recover from a flat spin, and spin in. didn't ever hurt it much when it did. again, more rudder area would have probably fix that.
TN
RE: Sig Hummer
I have a Hummer but have not flown it yet. I don't have the plans but I think you can balance it on the spar. 1/8 up and down on the ailerons should be ok to start you may need a little more than that. I don't think 1/8 up and down on the elevator will be enough, I would try just under 1/4.
My Feedback: (18)
RE: Sig Hummer
I have a kit and can check it for you if needed but I am thinking the same as the rest of the guys on the spar. I generaly set throws a bit more around 1/4 each way. I have had 3 of these. 2 with .049s and 2 channels and 1 I "T" tailed, 4 channel with a OS .10! Boy would it go!. Let me know if I can help.
Bob Harris
Early RC Models
www.earlyrcmodels.com
Bob Harris
Early RC Models
RE: Sig Hummer
The guys were dead on.
I checked my plans -- CG is the center of the spar for the kit. Throws are 3/16" up and 3/16" down for elev. and aileron.
the "other" andrew
the "other" andrew
