Building and flying the LST 1/2A Trainer
#528
RE: 1/2A trainer anyone?
Tweedy - sent you a PM on this plan.
I've build both the Tri-Squire and the 'Lil Tri-Squire and they both flew great. Looks like another to put on the to-do list. Hmm, I've got my old Sterling Mini-Mambo hanging right behind me - wonder how good it would be to upgrade to todays standards? Not as gentle as the LST would be, but maybe a fun second or third plane for a newbe or to learn single channel on.....
#529
MB, CANADA
LOL. I have Three young nephews.This plane is actually for them..Something tells me ,we`ll, be going through a few, first planes too. I hope not, but ,things DO, happen. NO p.m yet..DAVE B..
#530
Hey D Bronk, i got my balsa and have started building , ive got two questions for you 1) how did you do your wing tips, was it a bit of sheet 1/16th balsa allong the center of the outer ribs with the spars angled down/up to the edge (a pic would be great if you had one) and 2) what type of servos did you use ie. micro, mini or regular and would i be able to use regular size servos or will they be to big/heavy for the plane
thanks
ps. i included a pic of my wing at its current stage
fly bug hows yours comming along
thanks
#531
I beleive the tips a like the sketch, you'll have to freehand the tip ribs as the profile isnt given , I'ed say make them from 3/32
#532
See this post for the wing tips. http://www.rcuniverse.com/forum/fb.asp?m=3337578 Then scroll down 2 posts to see them built.
The tip shape is shown on the plan. 3/32" is good.
#533
Dave,
I've just been re-reading through this thread and I have to say that you're really doing a great job. Lots of patience and perseverance to do a quality job and everything from scratch, including custom skis. The photo documentation of the process is going to be greatly appreciated by anyone who builds this plane.
Actually, the input from everyone has really brought this project along.
#535
MD
ORIGINAL: Aussie Damo
Dave have you maiden yours yet?
Tweedy, thanks for making those plans available.
#536
MB, CANADA
Sorry my computer stalled while writting a post ,but I took a picture of the screen, before I re-booted ,and lost it.You might have to save the pic ,magnify it and the delete it when you are finished.
#537
UT
Hope sombody is able to make use of the skysquire plans if you see any errors on the plan please let me know I am always looking to improve them. I am currently drawing a cad version of Goldbergs 1/2a skylane. let me know if there is any interest and I will past those as well
Richard
Richard
ORIGINAL: flybug
Actually all I need to do is cover it, get it balanced, but I am reading up on how to cover http://www.rcuniverse.com/magazine/a...?article_id=67 also my engine is on backorder so long story short project on hold for a bit, but watching this thread very close. For me it was tough at the beginnig not even knowing the names of the different parts, but looking back it was an easy and fun build (the wing was the hardest) now all I want to do is build
#538
MB, CANADA
HOW DUMB, can I actually GET???[&:]A little P.offed at myself now[:@] If you`ve been following this build ,you`ll see the most obvious problem..
#539
MB, CANADA
BACK on track again.Screw-up,is straightened out.My intentions for the lines through the firewall ,was to use NO silicone etc.to seal the lines ,from having fuel seep around them..I drilled a slightly undersized hole fuel proofed the 2 holes,and pushed the lines through,for a friction fit.Worked perfectly ,except, I put the hole for the pressure line right dead center of the engine mount ,Exactly in line with the ,music wire ,front landing gear[:@].FIXED it, by useing a brass tube ,and SNAKE-ING, it around the music wire..
#541
Lookin' good. You're going to run out of excuses not to fly pretty soon.
Here's a tip that'll save you some hassle on fuel tanks, especially when using a third line. I used to use the Sullivan tanks, but I switched to Hayes because they are easier to setup and the stopper takes up very little space. Just plug the lines in and go. No cutting and bending brass tubes.
#543
MB, CANADA
Fly BUG,, LINK to a maiden ,hopefully in 2 days,TAXIING runs for sure Got to let castor oil cure in the cylinder for 24 hrs..that reminds I`ve got to wash the engine out ,and do that..3 year warranty from SIG so I better follow the instruction sheet.I would like this MILL,to last ,at least that long,if possible..
ANDREW Nice tank.I started useing GREAT HOBBIES,they`re good.I Ordered an engine Monday AFTER buisness hours . I got it yesterday.No CREDIT card needed got it COD.I`ll be useing them a lot, in the future.The same engine in Winnipeg $30.00more not includeing fuel .Thanks for that ADDRESS. way back when
HOG ,The plane is for my nephews .I want them to be able to ,Fill`er up ,without them burning fingers ..I don`t like CRYING..FOR now ,all I want them scared of ,on this plane is, the Propellor..Thats why the EXTRA fill line, away from hot danger.
I `ve been doing some final touches to the engine mount.GOT to cut the firewall bolts yet.Put some more padding ,under the hood I`m checking the balance, with every step, I do..have to mount reciever,actually A few loose ends to look after BUT yes ,I`m running out of Excuses, NO DOUBT about it
#544
WI
Lookin Good!! The pressures mounting D. Lets see her fly Honestly this is a great thread and I know anyone who reads this will be very appreciative on all the work and posting you've done for building this plane. All the best of luck on the maiden [8D][8D] Also the thanks goes to Bipe for posting his plan for this trainer!!!!
#545
i second DUSTOFF, D you have done an excelent job and all you hard work inspired me to make one, thanks to Bipe for the plans aswell, a couple of my friends in the district were interested in starting rc (cheaply) so i put them onto this thread and there should be a few of these flying around very shortly
#546
MB, CANADA
THANKs.BUT BIPER deserves THE Highest praise,.He`s a Great Embassador to the 1/2A hobby,with advice, all kinds of drawings ,for all of us,Organizing the ,"EVENT of DA`YEAR".He deserves a Good Guy Award..FOR ,me I just hope the pics bring some New BLOOD in to the FORUM..I`ll eventually put all the pics I have, on C.D,send it to him, and he can organize it,into ,an on-Line manual.This thread bounces around a bit, but .........
going to get the engine cleaned a lubed and call it a day.I think..C.S.I is on the tube so I`ll watch that and let the MIG hav a bit of a soak,once I take the mount off AGAIN...DAVE B.
#547
MB, CANADA
AUSSIE if you, or the BUDs, need a picture, of something ,and can`t find it ,just let me know, There`s a lot of pics I took,that I haven`t posted in the thread,all regarding to this plane.
#550
That is a great rx mounting, but it worries me some in the way it can transfer engine vibrations to the circuit board via the solid contact of that former and the servo connector shells.
In my day, my instructor had me wrap the rx with some fairly thick and heavy closed cell foam. (late 1970's)
Modern receivers may not be as subject to damage due to exposure to vibration as the old ones were, with the 'through hole' components standing tall on the circuit board, which could possibly resonate and crack a solder joint or printed circuit trace, but some isolation of the airframe from the rx is still probably a good idea on an engine powered plane.
I think you could just move that bigger rear block back or trim it to make some room and add someting soft to the former for the servo connector shells to press against, like the 'loop' part of some velcro or a bead of silcone glue, or a scrap of fuel line, also padding the crystal end balsa block. ... Just something to isolate the vibrations of the engine from the printed circuit board.
It's right clever though the way you have the servo connectors trapped like that.
I like how the rx is up at the top of the fuse, so solid and neat!
So maiden tomorrow!?
