Tomboy FF/RC
TN
RE: Tomboy FF/RC
Gnat! Don McGovern, right?? I still have that very old RCM issue around here somewhere! What a wild ride that must've been with an original red/gold .010 wailing away on the nose.[X(]
SC
RE: Tomboy FF/RC
ORIGINAL: DICKEYBIRD
SC
RE: Tomboy FF/RC
OK, I got to try her out today. Hey it was only 95 degrees and there was a steady 5-10 sea breeze coming from the SE off the coast. I made a couple of bad launches which only resulted in a slight decent to landing with the engine still running. I got several good flights and figured out the right speed and angle for the hand launch. I believe with a longer, smoother runway or bigger wheels she might ROG.
#31
GA
RE: Tomboy FF/RC
ORIGINAL: hfenn
Right, as in "Drove my Chevy to the levee...) Nove "64 is the issue I think. Good thing he stayed on the levee, you if a drove over, it being a Chevy it woulda sunk... Like A Rock!
#32
TN
RE: Tomboy FF/RC
ORIGINAL: hfenn
ORIGINAL: hfenn
I think McGovern also did the Berkeley Super Brigadier, Privateer, 1/2A Privateer, Navigator, etc, etc. Gawd, now you done got them old brain cells woke up and I'm wanting to build that 1/2A Privateer I lusted after a million years ago!! I read somewhere that McGovern never met a pile of a zillion balsa sticks he couldn't somehow work into a model design.
#33
TN
RE: Tomboy FF/RC
Oops, I got so wrapped up in nostalgic meanderings I plum forgot what I started to post about your great Tomboy pics. Classic design....blue skies....white puffy clouds....purty landing. It don't get no better'n that!
#34
SC
RE: Tomboy FF/RC
Oh, and DB, at our field all the fence posts are behind us
#35
GA
RE: Tomboy FF/RC
When you guys gonna learn not to doubt me. It's Don McLean
http://shop.fye.com/namepage.aspx?pi...oc=50244&sec=9
#36
TN
RE: Tomboy FF/RC
ORIGINAL: hfenn
And the plan sheet (Nov. '64 RCM) says Don McLain
Don McGovern wrote American Cobbler, right? Or was it American Ice Cream...I forget
#37
RE: Tomboy FF/RC
Nice to see you back, DB (even if your brain has turned to mush). You've been so quite, I thought maybe you had gotten frustrated trying to get one of your COX's to start and had jumped in the river.
If it's like it is up here, I expect summer has come to west TN, along with beer and BBQ.
#38
ON, CANADA
RE: Tomboy FF/RC
What a pretty sight.
There is a world wide Tomboy postal event that you may already be aware of
http://myweb.tiscali.co.uk/freefligh...tal%202006.htm
Vic Smeed is still around. He had a new design published recently in Aviation Modeler International, a real cute free flight float plane powered by a Cox 020 Pee Wee.
Although for FF you could set it up, turn everything on, place transmitter on ground, start your motor and let'er go. Time until you feel you need to grab the transmitter and bring her back closer to home. Not quite within the intent of the event but I think it should be. I like the idea of FF but there isn't much in the way any fields near by to fly. RC assist or call it whatever you like can fill the gap. That's the reason I like messing about with 1/2a Texaco. But then I am probably preaching to the choir!
I have my Playboy Jr ready to go but haven't been able to make the time to get out flying.
cheers, Graham in Embrun near Ottawa Canada
ORIGINAL: hfenn
#39
RE: Tomboy FF/RC
I just bought that copy of the AMI mag - the Damsel Fly. I thought I'd blow it up by about 25% and power it with a PAW 55 or MP Jet Classic and small R/C. Beautiful model. Does anyone know of a 'collected plans of Vic Smeed'? It would be quite a thick book I suspect.
#40
TN
RE: Tomboy FF/RC
ORIGINAL: Andrew
I flew once after the Tullahoma S.M.A.L.L. in Oct., then at the L.R. S.M.A.L.L. in June and that's it! It's the longest drought since I started flying r/c back in 1980.
#41
ON, CANADA
RE: Tomboy FF/RC
ORIGINAL: johnvb-RCU
Gotta love all those old time designs, Vic Smeed, George Stringwell, Walt Musicano, Goldberg, Shulman, and on and on and on. Two other favourites are the Vic Smeed Mad Cap and the Musicano (I think) Pee Wee Pal. With todays fancy copiers it is so easy to scale up or down to suit your needs or mood.
cheers, Graham
#42
SC
RE: Tomboy FF/RC
Two flights on the Tomboy today for a total of 1 hr+ airtime. I had to apologize to a club member on the same freq. ! Now if I could learn to land this good with elevator control!
#43
RE: Tomboy FF/RC
ORIGINAL: hfenn
Very funny about the landings. I used to get beautiful landings with a rudder/throttle Schoolmaster--just bring it in on a curve and then straighten it out at the end and watch the nose rotate up--prettiest landings I've ever done...20 years ago.
Lovely little plane, and the covering looks great. I'm guessing it's Airspan or Litespan, at least as it's called here. Great material for small planes like that.
Jim
#44
Beautiful! Must have spent a lot of TLC on it. Ihave a model with a DCMerlin engine which I am trying to convert to RC, not sure where to get a suitable servo. Any help appreciated.
