Need an idea! Found a motor.........
VA
I found this in my junk box the other day, I assume it's a Cox Texaco .049? It has a thimble drome plastic prop with what looks like "CB 3P" in raise letters and a snap starter. I've long since forgotten where this came from, but I'd like to start using it on something. Soooooo, the question is, what is a good application for this engine? I'm interested in early year pioneer designs, WWI or any odd antique looking plane if that would work well with this motor. If not, I'm not opposed to building something else, just so long as it's off beat. Any ideas?
Also, what range of props can I use and what kind of duration can I expect from the built in fuel tank? Thanks!
RE: Need an idea! Found a motor.........
If you just want to have fun in a hurry, build a 18"x18" open framework "PizzaBoxFlyer" for your engine. All you need is a pair of 3" chord elevons made out of 1/8" sheet, and build the frame from mostly 1/4"x1/4" balsa sticks. On one that I built, the elevon servos lay flat so that I could rig it with pull/pull linkage made out of spiderline thread,[ it saves weight].
VA
ORIGINAL: vicman
DNU, come race/goof off with us in Burlington NC next month[8D]
"pizzaboxflier", sound pretty cool. You have a photo or some sketches?
GA
ORIGINAL: tangerine-jack
DNU, SWR, PBF. All are decent choices for throw around initials.
VA
I have a habit of overlooking the obvious. I did an acronym search (military training!) on the forum to find out what DNU is, and the DNU (Das Not Ugly) seems like a good platform. I could modify bits and pieces, nip and tuck, add a hoozit here and there and it just might fit the bill.
I've been out of the loop for about 13 years give or take. Please excuse me if my knowledge is as antique as my radio gear. I'm trying to catch up, but there are 40 billion posts on this site and I've only been looking at them for a short time. So far all you guys have been great and given me super advise, thanks a bunch!
OK, ready for more ideas................
GA
Hitec HS-55's, a good lightweight receiver and a 220-350mah nimh battery is your friend. No matter what you build, as long as it's 1/2a, that is good running gear.
BTW, Tower sells 8-cell nimh flight batteries for cheap. All you need is a pigtail and a soldering iron to save lots of $$$ and weight!
With a Texaco engine there are at least two ways to go in terms of antique. Either a scale model of a full size antique plane, or an antique model airplane. In fact, the Cox Texaco engine was designed and manufactured specifically for antique and old Timer model airplanes. The name comes from a contest that was originally sponsored by Texaco. Later, it came to represent several events flown at Society of Antique Modelers contests. The SAM events are what Cox developed the engine for. There are literally dozens of 1/2A Texaco designs available, both scale and contest types.
Bob Holman sells many laser short kits for the Cox Texaco engine: http://www.bhplans.com/oldtime.htm
BMJR sells several Cox 1/2A Texaco kits, too: http://www.bmjrmodels.com/catalog.cfm?ID=Texaco
Both sell a design called the Rambler which is probably as good as any 1/2A Texaco model.
If you want cheap and dirty then a couple of 36x6 built up wings joined on a profile fuslage with a more or less 3D cowl, sheet tail surfaces and make it look like your favourite WW1 fighter. OK, THREE wings if you want one of "those tripes". In that case 5 x 32.
It would come out light and be a small and close in blast to fly. To tone down the speed a7x3 or 8x3 to hold back the RPM's a bit. But no inverted as there's no clunk in the tank. Keep it all positive G down to no more than zeroG and it's good.
TX
didnt I just see an Eindecker (sp?) done up here... somewhere... or was it a Taube
There was also the Bipe DNU & Triplane DNU variants thread a while back, those looked WW1esque
ok, found it, Eindecker post 75 of the "What are you guys working on" thread... but it was for a smaller motor- 010.
Still, making a DNU/Stick look like an Eindecker wouldnt be too hard.
tangerine-jack, one very important thing I totally left out is that some of those kits I linked to are R/C and some would need to be converted to R/C. I went back and looked at your posts and see that you build from plans and have been around the hobby since the '80s. Still, I just wanted to add that info. When I see model designs I tend to only see what I'd do with them, sometimes overlooking the designer's intentions altogether, FF or R/C, they're sort of all the same to me. I guess that's good and bad.
VA
All right, cool. I've got an idea. I'm going to take the DNU wing, make it a bipe, and use a profile fuse with sheet tail. A couple of questions:
1. do I have to shorten the wingspan when going bipe?
2. where is the new CG measured from?
3 is aileron or rudder better with the bipe, top or bottom wing for ailerons?
4. does the radio and servo mount on or through the profile frame?
5. how is the fuselage attached to the wing, I assume permanent, or is there another method?
I thank you all for your input, I'm lookin forward to this project!
GA
TJ, the DNU wing is actually an ACE wing. You can still get the ACE foam cores from ehobbies for pretty cheap!
At this size, permanently attaching the wing is easiest, but bolt-on will work with some effort. BMatthews introduced me to the center bolt concept, and it looks like it will work fine. The object is to bolt the wing to the fuse at the spar. Two bolts should be all you need.
VA
Hmmm, well I priced the foam wings and priced the balsa, and then got the balsa. I'm not "cheap" I'm "thrifty" So a built up wing it is. I saw the post on a bipe stick, and I will use that as a pattern, but how thick should the fuse be? I'm thinking 3/16th? Would this be strong enough or should I use 1/4"? I know weight is a trade off with the extra wing and the .049 is only good for so much power.
Yup, construction will start tonight!
VA
OK, I consulted with my chief engineering design coordinator who downloaded the aerodynamic parameters of the airframe and gave me excellent fuel usage calculations, then construction began. At the rate it's going, I might be done in 2 days.
Looks like you're showing a profile fuselage []? If so, then 1/4 balsa would be bare minimum, 3/8 would be less prone to flexing and twisting. I thought you were talking about building a box fuselage? If you are building a profile 1/2A plane with a 1/8" thick fuselage, then laminate both sides with 3/4 oz cloth!! The engine mount area would need considerable work to keep it from tearing out if you are building a 1/8" thick "profile" plane. Hopefully, what I saw in the photo wasn't what I thought I saw!
VA
combatpigg,
ummm, well.... I just fired my design engineer- all he ever wanted to do was play with the computer mouse and get high on catnip. Upgrades in progress, laminating a 1/4" profile onto the existing, that should make it nice and strong. It's all good, learning curve ahead.......
flyingrog,
checking the logistics of the trip now. I am about 4 hours away. I think I might be free that weekend. Is the event only one day? You got a schedule of events?
flyingrog,
TJ, I'm glad to hear you got it under control now, nothing worse than getting bad advice. The profile kits for 1/2A usually have 1/4" cheek cowls that go back to the spar line of the wing. This will not add much weight, but give the plane some style and beef the engine mount area. Then for the ultimate in streamlining, make the firewall blend to the outline of the fuel tank. Do you plan on putting the radio gear inside the wing?
combatpigg,
flyingrog,
combatpigg,
flyingrog,
VA
ORIGINAL: combatpigg
