41 yr old throttle
41 yr old throttle
Hi. Has anyone here had any experience with this type of Cox throttle? It reminds me of one that was presented here on the forum a while back in that it uses a barrel with an opening that rotates inside a larger tube, sort of the way a carb barrel operates. Sorry I can't remember who developed the one shown here on the forum. Anyway, it looks like a simple solution to the throttling problem, though I have no idea how well it worked.
RE: 41 yr old throttle
rainedav,
I beleive they were push/pull not rotateing, and also had a rotating barrel fitted in the venturie- only seen pictures myself. heres another shot.
Stewart
Stewart
PA
Similar to a ROTO-VALVE exhaust throttle I had on a FOX 15 powered Live Wire Trainer (1959).
It was a single channel rudder only ship with "Quick Blip Hi-Lo"engine control.
All control was by rubber band powered escapements.
Maurice
Maurice
Ah, it was David Fritzke who was working on the tube-within-a-tube throttle. I couldn't remember at the time of my post:
http://www.rcuniverse.com/forum/m_28...tm.htm#2874106
When I saw that old Cox throttle I thought it worked on the same principle. Similar, but one rotates and the other slides.
rainedav - I have a cox engine with that exact throttle set up. It seems to work great, I don't have any numbers, but is does idle down amazingly well. My uncle gave it to me, he does not remember the details as he bought it when he was a kid.
Chris
Chris
