Pacer
RE: Pacer
Very nice old plan --
A Gene Rock [link=http://my.pclink.com/~dfritzke/pacer_cadplans.pdf]modern rendition [/link]
I have the original article in PDF -- American Aircraft Modeler
GA
RE: Pacer
Ace kitted the Pacer. I built one a number of years ago. It came in at the specified weight which was about 22 oz using the "old" ACE foam wing. At that weight, it was a little heavy by today's standards. I had a TD on it and it flew great as long as the TD was at RPM. It flew and tracked really well. Cubans and other basic aileron and elevator aerobatics were not a problem.
RE: Pacer
I understand that Thundetiger has the old foam wings available. I would like to have built one with at Norvel 061, but I waiting on whether additional glow plugs are going to be available. I built the "Simple Simon" from Model Builder years back with the ace tapered foam wing with a TD 051. No throttle control, boy was it fast. If I can't order the thunder tiger foam wing, I might build Gene's version. Thunder tiger uses amazon.com shipping network , but it says it can't ship to Canada. I've had no problem buying books through amazon.com. Go figure.
RE: Pacer
Awesome little airplane. I added rudder to mine and it did great snaps and spins, all with the TD screaming.
I flew that thing until the balsa virtually melted from oil soaking. After it finally came apart you could squeeze the oil out of the wood.
I probably had more fun with that plane than just about anything I've ever flown.
Dave
Dave
RE: Pacer
Ok, you Pacer vets. I have a brand new TD .09. This thread has got me to thinkin' about those classic TD designs like the Pacer, Mach None and GLH. Anyway, if you were going to scale the Pacer up for a TD .09 what span would be ideal? It's 42" so I'm think 46 1/4" maybe? That's 110%. 115% would be about 48 1/4". I know there are some here that would put an .09 in the original, but that would be a bit too ballistic for me.
NJ
RE: Pacer
If I may IMHO, I have been researching for a classic pattern plane. I have read that because it's built like a tank to begin with it becomes reliant on weight and is why the design is very specific about nothing more than a .049 TD. Apparently you only have to knock off a couple of ounces to make it pretty hot.
However, regardless of what happens to the .049 Pacer I have in the making I am definetly going to build theSuper Pacer, I have a new .25 itching to be put in something.
GA
RE: Pacer
1/2A:
I built the Super Pacer also - about one year ago. It flys great and tracks well also. I am using an OS .25FX and it provides plenty of power sufficient for knife edges, etc. If you like the 1/2A version, then you are going to love the .25 size.
MN
RE: Pacer
Here is the link to the Super Pacer plans, also a Gene Rock multi-page PDF file.
It is a really good flyer, a .25 is plenty of power.
http://my.pclink.com/~dfritzke/superpacerplans.pdf
Dave
Dave
My Feedback: (18)
RE: Pacer
Guys, I posted in the vintqage forum on a hobby shop in Suffolk, VA called Eagle Hobby. Tom Atkins is the owner. He has a Super Pacer kit NIB along with quite a few more older kits at the older prices. He also have several Ace foam wing kits in stock. Give him a call. www.eaglehobbyshop.com. Tell him I sent you!
Bob Harris
Bob Harris
MN
RE: Pacer
RAINEDAV,
I may have a single sheet pdf, but not a cad file per se.
It may be a vector format pdf however.
PDF files are easy to print at other scales, just specify what
you want when you print it. I printed Genes letter size tiled Papillon plan
enlarged onto 11x17 to see how it would look as a .15 size plane.
You may want to try some of Dick Sarpolis Hammer designs as well
(most published by FM) they are easy to build and fly great from what I hear.
Dave
Dave
RE: Pacer
ORIGINAL: rainedav
I doubt you will find it much faster with the .09, but it will have a fair bit more authority from hand launch and in climb/vertical lines. You can always run an 8-3 prop and tame down the top speed too.
Yeah, I know you predicted people would say this, but I had to anyway! It's a real nice, functional sport aerobatic design, I would encourage you to build one.
MJD
RE: Pacer
ORIGINAL: MJD
MJD
MJD
MJD
RE: Pacer
RAINEDAV --
Check out Andrew Donatelli's (AKA: Bipe Flyer) [link=http://www.blackflight.com/]TilePrint program[/link] -- there is also has a link at the bottom of Dave Fritzke's page. It will allow you to resize PDF files to whatever scale you desire.
[link=http://www.rcuniverse.com/forum/m_1369249/mpage_1/key_tileprint/tm.htm]Here is a link[/link] to the thread in this forum discussing Tile Print.
RE: Pacer
Thanks, all. Photoshop CS opens pdf files (it's Adobe bloatware, too) so I can enlarge each page and print no problem. I just thought I'd ask about the cad file since I would be able to redraw stuff to standard wood dimensions.Sometimes when you enlarge stuff by increments other than 25% or 33% you get goofy sizes. But, that's no problem. It's easy enough to round things off to the nearest basla sizes like .61 to 5/8, etc.
NJ
RE: Pacer
ORIGINAL: flyswatter
1/2A:
1/2A:
Great minds brotherman, great minds
NC
RE: Pacer
alright yall I got a new ace pacer with an OS on it.. im guessing a .10? but no landing gear? are ace pacers without landing gear? or did my seller take it off? thanks!
NC
RE: Pacer
alright but on my plane.. the exhaust from the engine is not flush w/ the bottom of the plane... I dont know if this is how it is supposed to be but. will that pipe catch on the grass or do you think it will be alright...
