Norvel .061 which ARF
IA
Built from scratch Pylon racer but interested in ARF or kit for the .061 Norvel - any ARF or kits out there - flew the scratch build but was not very good in flight.
Any info is appreciated.
coop
coop
RE: Norvel .061 which ARF
Hey Coop, not much in the way of ARF's unless you convert a parkflyer..there are kits..Quantum models and thundertiger4u carry the Ace simple series ,,there are a few mistakes on the ttforu site..about 10 models ...Rog
most all of them are for .049-.07
The 1/2A Shrike:
Pros:
Wicked quick
Inexpensive -- $25 from [link=http://www.quantummodels.com]Quantum Models[/link]
A real hoot
No setup time at the field -- fuel and go.
Cons:
Wicked quick
Not a second plane or for faint of heart
Can be a handful on launch - will snap if not on your toes
Non-standard construction due to thru fuselage spar and wings being built integral with fuselage; must be careful with alignment
Due to speed, flutter can be immediately destructive
Internal space is tight
Pros:
Wicked quick
A real hoot
Cons:
Wicked quick
Coop you wanna stay away from the shrike...until your 5th plane or so... the low price also reflects the $20 worth of hardware your gonna need to put that thing together..the other thing I didnt pro in with the simple series is they have some of the best (well most complete) hardware packages in the business,,I'm sure anyone who's built one will agree...Rog
http://www2.mailordercentral.com/quantummodels/
this is the other site, a bit strange to navigate go to manufacters and go to Ace and then click on aircraft..a bit better descriptions of the planes...
Coop,
On the other hand- if you have much flying experence the Shrike as a blast and maybe the best airplane for just speed fun there is.
Put a Norvel .061 on the nose of the 1/2 A and it goes were you point it- great fun to race as well.
Coop --
If you want fast, but on a more conventional planform, look at the ACE Simple 400, Lanier Dominator 200 or the SIG Hummer. The Simple 400 and Hummer are available from Quantum Models. Tower has the Dominator - may be built with a V-tail or conventional R/E.
IA
Guys - thanks for all the info - I am trying to upload a pic of my scratch build - I have a feeling it will not last long - was very unstable and was also new motor.
cop
cop
IA
Thanks - little rough - my first scratch build - running one aileron and need to check CG - last night had several helping and many suggestions - some said 1 - 2 inches back for CG
Start at 20 to 22% of chord, then move back if you want more pitch sensitivity. If it is a little squirrelly, your CG may currently be back a little too far.
I'll compromise with Hogflyer at 25% --
Check your present percentage -- if it's a handful now, I would move it forward.
IA
Thanks - excellent info -
Ok I am new at this - what would you recommend for starter - are you using standard starters or 1/2 a starters - where is the best source for decent yet reasonable starters.
I was using a friends starter last night
thanks
coop
thanks
coop
cooper,
I was afraid it was only one aileron. In your case you have it on the wrong side of the wing. You want it so it's on the outside of your lap so the drag it makes helps keep your nose up as you make your turns. As for CG I would start at 25% also.
LAter,
Tim
LAter,
Tim
IA
checked my CG - It was very tail heavy - moved battery added little lead - at 20 - 25%
Ordered the Sullivan starter - waiting for weather and starter
thanks for info and help
