Prop selection.
Prop selection.
Okay I just broke in the motor for my little 1/2a trainer-like plane. It feels a bit heavy to me for its meager 30in spand and about 5 in chord. so I have about 140 sq inches of wing area when you subtract the part obstructed by the fuse. I think the wing is going to be overloaded but I do not have a scale to figure the actual loading (hmm post office???) Well according to my digi tach my little AP .061 Wasp was spinning an APC 6x3 up to 31k RPM with good throttle response (transition) I am thinking about putting my APC 7x3 on. I also have a MAS 9x6 but I think that would be way to much prop. What would you use?
TX
RE: Prop selection.
I would start with the 6X3.
I have had an APC 7X3 on my Norvel .074 and it appears about right for that engine.
I suspect the 7X3 would be a load on the .061.
RE: Prop selection.
ORIGINAL: Mr67Stang
You might try a 6x3 MAS -- blade area is a little higher than the APC.
RE: Prop selection.
ORIGINAL: combatpigg
Man, those AP WASP engines are getting stronger! Mine only turns a 6x3 in the 17,000 realm.
PA
RE: Prop selection.
Sounds like you're using the tach correctly. Sometimes I'll shine a flashlight into the prop while taking a tach reading - Seems to help when I'm in the garage. The readings on my tach jump around a bit (8k, then 12k then 18, then 3k, etc) but they usually settle or at least repeat around one number, and that's what I'll use as the reading.
I normally use a 6x3 APC on my Norvel .061 Big Mig and it turns around 17.5. My Norvel .061 CL turns a 7x3 APC at around 15.4k.
EG
EG
RE: Prop selection.
Man I thought that was high too.(31,000 where do I get one!!!)..my little hobbico tach worked great for about 4 months, now it jumps all over the place...6 x 3 is all you want on that engine...you might be ok with 7 x 3 since its a trainer , but I wouldnt bother...maybe both of our tachs need new batteries?....since your new to the little ones..the term "texaco" is about slowing an engine down with a larger prop to make the tank last longer to keep the plane flying/climbing longer..I am not sure but I believe it is a free flight (no radio) event...Rog
NC
RE: Prop selection.
If you are taking tach readings in a shed or building with flourescent lighting expect to get some interference.That is how you check your tach,by the way for accuracy,hold it up to a flourescent light.
PA
RE: Prop selection.
Kidding aside, fluorescent lights do cycle on and off and at a very high frequency - kinda like a strobe light. My shop lights "tach" at 3600 for 2 blade, 2400 for 3 blade. The RPM number doesn't vary at all, and I'll guess that means that my tach is just fine!
EG
EG
VA
RE: Prop selection.
ORIGINAL: flyinrog
VA
RE: Prop selection.
I don't like the idea of my airplane flying off into the sunset, so I will be using the radio assist (I think it's rudder only, but I'm not sure). In any case, this thread is being very helpful!
RE: Prop selection.
ORIGINAL: flyinrog
free flight isnt allowed at either of our fields..[]
RE: Prop selection.
Okay, I have flown this little bird and had a beauty of a day to do it. Rog, you've seen the video. Well with PROPER daylight I believe my tach readings worked out a little better. I showwed a 15,500 RPM a WOT.
