My Shrike Progress
NC
My Shrike Progress
Ok, I finally got the engine mounted and the front rounded(I hate sanding) so I cheated a little and used my dremel...I'm ready for the wind tunnel now and then a little more fine sanding to achieve maximum speed! In the interest of minimizing drag during the maiden I think I am going to shave my legs......ok that's a little extreme....maybe just a swimmer's cap!
-Bill
-Bill
RE: My Shrike Progress
Nice work, Sarge! I didn't realize how much bodywork went into a 1/2A Shrike. Shaping balsa isn't something to be hated if you're set up with tools to make short work of it. The problem is that carving and planing are really the right ways to knock 90% of the wood down, but it seems that alot of guys who dread shaping wood do so because they think that 100% of the shaping process is done with sandpaper. Sanding seems like a safer way to go, but it is the slow boat to China.
WA
ORIGINAL: combatpigg
Nice work, Sarge! I didn't realize how much bodywork went into a 1/2A Shrike. problem is that carving and planing are really the right ways to knock 90% of the wood down, but it seems that alot of guys who dread shaping wood do so because they think that 100% of the shaping process is done with sandpaper. Sanding seems like a safer way to go, but it is the slow boat to China.
Never heard of that one before a potato peeler?...well I do know the shrike offers to let you cover the fuse bdfore you start the wing and now I know I would do it that way as mine came out a bit sloppy in the covering dept...should fly weds morning with Bill so we'll see how it goes...Rog
ORIGINAL: vicman
When I saw you online this early, I thought "oohh this aint gonna be pretty". Alas its nice to hear cool heads prevailed.[8D]
NC
Rog and Bill,they said they took another hit on 19 out at Snow Camp.Beware.Glad y'all waited on the fog,Brent put his P51 in because of lack of visibilty at CopperHead in the morning hours.[:@]
TX
NC
Almost got the wing done now....I hope to fly it sometime next week! With all this crapy weather at least it gives me time to build!
NC
Usually when I read about "fog" it has something to do with my mental capacity. This context is a happy change.
The only thing I can contribute about flying in fog is back when I used to fly gliders. There were early mornig foggy times when you'd launch and the model would disappear at the top of the line. Then when it landed (quickly because there would be zero lift in those conditions) the model would be dripping wet from the vapor condensing on all the surfaces.
NC
Does anyone know which aileron strip set to use with the 1/2a shrike. The plans say Carl Goldberg #402 which I ordered but when it came in the other day the hardware was way too big for the plane[]...if anyone has built this plane do you remember what you used for the aileron strip set??
thanks
-Bill
thanks
-Bill
I ordered the one the plan said and it was wrong too..thats why I went with a servo in each wing ..hope it works okay...mine doesnt exactly balance it sorta teeters.,.so it could be a handfull in the air...but you'll be there when it happens...Rog
Hi Bill,
It's been fun watching your progress on this one. My suggestion would be to just bend your own A-links, it's just two 90 deg. bends in a rod threaded at one end. You could take your plan to the local LHS and see if the have a prebent set that will work. If not they should have the rod, clevisis, and links to make your own. You can bush the rods with brass,aluminum or plastic tubing if you want to. A method I've tried and really like is to use an unbushed link. Put some vaseline on the rod then glue on your 1/4" trailing edge stock with epoxy. As the epoxy cures wiggle the link a bit every few minuets to keep the rod free. Once the epoxy cures you have a nice slop free epoxy bushing.
Darren
Darren
NC
ORIGINAL: rrragmanliam
Hi Bill,
Darren
Hi Bill,
Darren
Thanks!
-Bill
FL
Is that the .10 size shrike? If so, I have a few comments about mine (stories too). I also custom bent my own rods with one end threaded. I used plastic pushrod sleeves as bushings.
My Feedback: (9)
WA
Dang it! I've got most of a new fuse put together today and just have the wings and tail to cut from the plans.
This is an insanity you know. lol.
How does an unsold 4200kv inrunner sound?
Alex
Alex
