Two Channel Set Up ?
RE: Two Channel Set Up ?
Most of us are used to the primary rolling function and elevator on the right stick. And in this case rudder combined with dihedral forms the primary rolling function so on the right it goes.
A few years back I flew with one of the old two stick two channel Tx's. More than once I tried to bend the rudder stick to pull up the nose....
On my rudder and elevator 1/2a stuff I use my old two stick, two channel Futaba radios, so I end up with rudder on the left and elevator on the right. On my 1/2a planes with ailerons, I use my JR gear and ailerons and elevator are both on the right. I did run into trouble once, where as I forgot that the two channel ME 109 I was flying (with my JR radio) had ailerons and elevator only and couldn't figure out why it wouldn't turn when I was giving it full rudder input. It hit me after I got her down that it didn't have rudder control! Duh!
NC
Thanks to the Aero Ace and the early Fighter Birds I was surprised at how quickly I adapted to using two sticks for RE. HOWEVER, it always takes me a while to get used to it and I always have to readjust when I got back to my "real" transmitters.
Another problem I have is on the ground with my RE 'Bees (Lazy, Speedy, and Baby - I LOVE dem Bees). When taxiing it is natural to use the left stick for ground steering but with rudder on the right stick on a RE application, which is where it should be IMHO, you have to adapt to 'steering' with ailerons. (I just pretend that I intended to do a donut, but don't tell anyone.)
All of which is to say, keep RE on the right stick.
Confused? Send lots of money by return owl for rush delivery of my new CD, "how to make it look like you know what you're doing." This is basically the story of my life. All rights reserved.
ORIGINAL: DanCarey
I not sure what mode but it is throttle and rudder on the left and elevators and ailerons on the right
I don't know why I asked though, in both mode 1 and mode 2 the ailerons and rudder are the same. [sm=red_smile.gif]
Mode 1:
elevator/rudder on the left stick
throttle/airlerons on the right stick
Mode 2:
throttle/rudder on the left stick
elevator/ailerons on the right stick
Mode 3:
elevator/ailerons on the left stick
throttle/rudder on the right stick
Mode 4:
throttle/ailerons on the left stick
elevator/rudder on the right stick
I can fly on either stick, but I prefer the right. I find it a real pain to taxi with the right though, that's why I do the mixing. I have an old Futaba 2-channel with the elevator on the left and rudder on the right. I don't like it!
IL
I use the same method I would use if it were any 4 ch plane. Putting the rudder on the aileron stick leads to bad habbits in my opinion. More so if you fly inverted. If you are just tooling around, it will most likely never even be an issue. When inverted, the ailerons don't reverse, but the rudder does. Thats what I meant about bad habits. Almost bit me a time or two.
Mike
Mike
When inverted, yaw and pitch reverse, roll stays the same. A 2 channel model flying inverted with rudder is much like flying with ailerons.
IL
So if you train yourself to use the rudder on the aileron stick, you may end up pulling the wrong aileron direction because of it when you go back to a "normal" setup.
Mike
Mike
No, it's the same. I miss spoke about the yaw reversing, or rather I didn't explain it properly - it depends on the dihedral.
When you roll with a rudder it doesn't roll half way and then roll back, it keeps rolling in the same direction. And, because we're talking about a 2 channel model with dihedral which becomes anhedral when inverted, the plane actually has adverse yaw inverted, which is in the opposite direction of the rudder and the actual direction of the stick. On a plane setup without yaw/roll coupling, like a pattern plane, the rudder reverses. That's moot anyways, because you'd have no roll control with just the rudder.
As seen from the ground:
Wing has dihedral > left rudder stick > rudder defects left > plane yaws left > plane rolls left >
plane is inverted > wing now has anhedral > left rudder stick > rudder deflects right > plane yaws left > plane rolls left.
So, on a model where you could use the rudder and no ailerons, the rudder behaves the same as ailerons. Come to think of it, using the rudder on the left would teach you bad habits on a 2 channel model because when you go back to a 4 channel pattern ship you would be expecting the plane to roll with left stick, when in fact it will only yaw.
Whirlyspud,
Please don't think that I'm trying to shoot down what you're saying. It's about the pilot's perception of what's happening that's important. If you feel that flying with the rudder on the right stick causes you problems when going back to 4 channels, then it's real for you. Much like how people perceive flying in the wind differently. Heck, I quit playing a particular WWII simulator because I felt that it affected the way I flew RC.
IL
No big deal. I noticed it flying a 3ch park fliers for a few weeks. When I went back to my normal plane, I came real close to crashing it. That was when I said no more rudder on the aileron channel.
Mike
Mike
I agree with Bipe on the perspective of flying one radio vs. another. I've flown 2-ch 2-stick, 7-ch single stick, multi-channel 2-stick, and even wheel control 2-ch. It doesn't matter to me what style of radio, or the mode - I just adapt to the radio I'm flying. But there are others I know who don't care to fly anything other than a multi-channel 2-stick so they have the same feel. It's what ever makes you comfortable in your flying, not what others think you should be flying.
Bipe,
Ever try something like the Futaba FP-2FN 2-ch?
Hogflyer
Bipe,
Hogflyer
IL
I had that radio about 20 years ago...... in a car. I agree, if all I was ever going to fly was rudder and elevator, I'd have both on the stick and not think twice about it But, that is not the case.
Mike
Mike
ORIGINAL: hogflyer
Bipe,
Hogflyer
Bipe,
Hogflyer
I'm an instructor at our club, so I use a lot of different radios, but I still like the feel of mine the best. It's like driving someone else's car. The funny thing is that I adapt to a plane easier than the radio.[sm=50_50.gif]
ORIGINAL: Bipe Flyer
Bipe, I have two older Futaba AM radios I use for 1/2a stuff and one transmitter had the elevator on the left, and rudder on the right like you mentioned. I opened up the case and after some slight modifications, were able to rotate the gimbals 90 degrees so that The right stick moved up and down and the left side to side as a normal mode two set up would be.
ON, CANADA
I mix my rudder to ailerons so that I can use either stick. That way I can taxi and takeoff with my left hand and fly with my right.
I do the same thing except I usually fly mode 1 (occasionally mode 2 just for variety). I will use the rudder stick for taxing and when flying 2 channel sailplanes for "rudder" effect and aileron for normal aileron turns - I know the effects are not really like that but it does help keep the brain and fingers thinking rudder/elevator/aileron even though you are only rudder/elevator.
I think it is pretty much personal choice and in the end it is whatever works.
cheers, Graham
