Dang It!!!
Dang It!!!
I did a nose dive right into mother earth and now the needle valve on my sure start is just spinning around and arround and it wont start...any ideas of what could be wrong? (the crash wasnt my fault...cheepo little control horn i found in a box of my dads old stuff!!)
RE: Dang It!!!
hey rog, i put some fuel line on the needle and now it seems better than before! havent started it yet because the neighbors get pissy because of the noise... i'll have to wait to get to the field
RE: Dang It!!!
alright, i went outside and ran it for a few minutes, (had to run when neighbors started to run over yelling at me!)
but anyway now the needle stays in a spot where i dont need to adjust it anymore! thanks rog for the fuel line idea
RE: Dang It!!!
ORIGINAL: JasonFalls
If you really want to piss em off I have a TD .15 you can borrow for a while.
Rrragman
RE: Dang It!!!
Here's what ya do....you got a kickin' stereo system? Get yourself a CD of bagpipe music. Crank it UP, set it to 'repeat', and head off to work. Works better if you can leave your windows open a crack! German or Irish beer-drinking songs work well too.
TX
RE: Dang It!!!
I kinda like the idea
"I see your Lawnmower, and raise you an openpipe .40"
kinda like a little concert, lets all run engines
Or fire up 2 049s and tweak the rpm for a massive harmonic Warble to drown out the Lawnmower
RE: Dang It!!!
"harmonic Warble" I like that. I used to crank up Public Image Limited's Flowers of Romance for obnoxious neighbors. A really great album after the tenth or eleventh time you play it, have a listen:
http://www.amazon.com/Flowers-Romanc.../dp/B000005JAC
RE: Dang It!!!
skaliwag, I'm gonna have to side with rainedave on the free meals comment. I was born in New Orleans and raised up in L A. Heck all an armadillo is, is possum on the half shell!
I did like the Cox .09 Idea but I would want to put a cheerleadder megaphone near it just right so that it focused in the "proper" direction.
My personal idea would be to find some wav. files of cats in heat and loop them for playback and aim that at the neighbors! A mix of these should also creat a harmonic warble that would be unequaled elswhere in nature! Heh!
Robert
Robert
RE: Dang It!!!
Ain't NUTHIN' finer'n eatin' possum stoo out back by the seement pond. (Havin' Ellie May prance around fer ya he'ps too.)
p.s. Possum stew is great...really! So's squirrel.
RE: Dang It!!!
