Surestart upgrades?
Surestart upgrades?
Hi, I know theres already been a post like this but I cant find it. Anyway, Are there any upgrades you can put on a surestart for more power?Also, what size spinners work best on these engines? I have a dubro 1 1/2 spinner, and that just shakes the crap out of my plane. Any suggestions?
GA
RE: Surestart upgrades?
Jason, peak performance can be obtained without huge modifications. Make sure that you are running the right prop (like an APC 5.7x3 or Cox 5x3) and using good fuel. I like 35% with the bottle topped off with castor. After that, mylar reeds are supposed to be a "hop-up". Not a whole lot after that is easy or for most applications worth the trouble. Somewhere, there is a sheet of performance mods for Cox engines. I'm looking for it...
ORIGINAL: JasonFalls
This is a really good question, so not to repeat/highjack your inquiry, but who does make good quality, SMALL aluminum spinners?
I see a thread here on the same subject..
http://www.rcuniverse.com/forum/m_39.../tm.htm#397493
MJD
I did some simple mods a while back that involved allowing the engine to breathe better, like removing the intake screen and tapering the intake port from having square edges to a bell shape. Along with PT's suggestion I might also mention balancing the prop and I have personally gotten more whoopies out of APC brand than others. I also remove the NV seal and spring and replace them with a piece of fuel tubing to limit vibration and air leaks giving more consistant runs and settings. Of course setting the piston ball helps a bunch too and is nearly required on the latest sets of motors. Experimenting with shims and fuel mixes can yield good results too. I got some running 24K static this way.
Other mods that are not so easy are cutting the exhaust slits for sub piston induction, and grinding/balancing the crank. When done right, they seem to help, when done wrong they can make the engine a nice paper weight and guys disagree about them. Stick to the easy stuff and you'll be pleased.
Do you actually need a 1-1/2" diameter spinner for that wee engine?
I have also heard that the TD heads give it more power-is this true?
OR
Jason
TD heads are for TD's so not true. The biggest bang for the buck is a Galbreath head for Nelson plugs and of course a Nelson glowplug. Add a Cox 5-3 Rubber ducky prop, 35% Nitro and the engine will be good for about 18K+ rpms.
This will not break the bank, the head costs $10.00 and the plugs are $3.75 each. Buy more than one plug. These are availible form Galbreath or Larry Driskill at "Kitting it Together'. I can't help you with a ball socket tool. Make your own, buy one on eBark or buy one from Davis Diesel.
After that it takes real nit picking of parts, experice and bench running with a tach. to sniff out more. Do you have it?
HTH - Steve B.
HTH - Steve B.
GA
Jason, just about any head is better than the original SS head. Look for a TD head or a Galbreath head w/ Nelson plugs or Tim's Turbo head.
http://www.hypercolor.biz/Products.html
https://ssl10.mysecureserver.com/kit...dex_store.html
how do you reset the piston ball?
Resetting the piston ball and socket joint takes a special tool that can be found at Davis diesel or you can make your own if you are good at machining. You can search on this forum for "socket reset tool" and should find a lot of info. I'm on vacation and not on my computer so I dont have pics of what I'm talking about.... any of you guys help him out?
OR
RD
All I've ever used is the standard so I don't know. Since Nelson no longer makes the std. I'll be trying the heavy duty plug when I need more. (the one with the ring/groove cut into it)
Regards - Steve B.
Regards - Steve B.
I have the tank conversion kit for the SS. Does the end of the supplied fuel line go towards the front of the tank or towards the rear?
ORIGINAL: burtcs
RD
Regards - Steve B.
RD
Regards - Steve B.
