A few questions about 1/12 HOB P-51
RE: A few questions about 1/12 HOB P-51
There are many ways to set up a steerable tail wheel. With the P-51 you have to decide if you want it in the scale location (more difficult) or extending off of the rudder (the more common method and much easier). For the second method simply secure a piece of wire along the rudder hinge line with the end bent 90 degrees and inserted into the rudder (similar to the way the aileron torque rods attach to the ailerons). The other end simply extends down and is bent to form an axle for the wheel. When the rudder is deflected, the tail wheel is, too.
OK
The tail wheel at the rudder sounds good but i have seen planes with tail wheels right on the rudder joint break the rudder off easily on ruff landings.....Thanks thought i think i will go with the tail wheel rudder location
Here's a picture of exactly what I was describing. The nylon hinge thing goes into the fuselage, the 90 degree bend in the wire goes into the rudder:
http://www2.towerhobbies.com/cgi-bin...?&I=LXJ931&P=7
I've used that style of tail wheel before. If there is any doubt on the strength of the tail, scarf 1/32 piece of plywood on each side of the rudder where the wire will penetrate. I had a tail wheel wire break out of a rudder on a plane that was flown out of a very rough pasture and this stopped the wire from breaking out of the rudder after that.
Hogflyer
Hogflyer
#31
ORIGINAL: hogflyer
I've used that style of tail wheel before..........
I then follow HF's advice and scarf a piece of plywood on either side of the rudder.
