AP Wasp .061 wont start
IA
i have a brand new ap wasp that i bought for my LST trainer. i am using the right prop, the right fuel, the right fuel tank, and a kwik klip glow starter. i have tried about 60 times to start it. it doesnt flood, it doesnt smoke, and it certainly doesnt start. i am at the end of my rope here. i am new to nitro and have almost no idea what i am doing. could someone please help by possibly identifing the problem. i spin it with a starter and nothing happens. i even bought a 1-1/4 spinner so i could use a bigger starter. what is wrong.
RE: AP Wasp .061 wont start
The first question I was going to ask you before I read your post was, can you get it to flood? I would look into that situation first. These engines SHOULD flood very easily. Get some fuel flow established. Make sure you got a strong glow on the plug and that all parts on the engine are snug.
I assume that you have followed the instructions that came with it regarding the needle valve and everything else relating to starting. Do you have the tank at the correct height in relation to the carb? Sometime this little bit of information is left out of engine manuals. If the orientation is not correct, the engine will either get too much fuel or not enough. This can be a big problem on smaller engines where the muffler pressure might not be enough to compensate.
ORIGINAL: jerusha
Take the spinner off -- it's just extra weight right now -- and you can more easily flip the engine thru without a spinner.
Flipping the engine with your finger over the carb mouth will usually pull fuel to the carb -- do you have fuel all the way to the spray bar nipple?
Drop 2 drops of fuel (max of 3) directly into the carb mouth and flip 2 to 4 times to distribute without your igniter attached. Attach the igniter and flip smartly. For me, having the prop horizontal when it comes on compression gives me the best flip speed. When flipping the prop, I usually place my finger near the prop hub and snap it thru. Having your finger close to the hub will give the best rotational speed.
If you can get the engine to run on prime first, you can deal with setting the mixture later. Running on prime will establish that you have sufficient compression and plug heat to run.
Keep us posted.
TX
Ahh, starters . Instant success or instant failure .
Maybe since all the manufacturing has gone
overseas at least one of the importers would
think enough of their customer base to supply
a well written instruction sheet. Nah
Ralph
Ralph
