modifications to an 049
#76
FL
RE: modifications to an 049
Update:
Yesterday I went to my LHS and bought some tubing($11 total) to make an "air intake carburetor". I started with a 1/16" hole which was too small so I moved to a bit that was slightly wider. Now with the hole wide open, it idles(choppy of course). I think this method is going to work. I just need time to perfect it, get the hole size correct, etc.
#80
LA
ORIGINAL: skaliwag
If you are not going to use em for a while.. Yes... Castor gums them up.
But a question: How/where do you apply it?
On larger engines I squirt some oil into the intake and flip it over a few times primarily to prevent rust on the ball bearings. But that wouldn’t seem to flush/preserve the fuel orifices on our small Cox engines?
