Go Back  RCU Forums > RC Airplanes > "1/2 A" & "1/8 A" airplanes
 Skydrill Build Thread >
"1/2 A" & "1/8 A" airplanes These are the small ones...more popular now than ever.
Old 10-15-2007, 09:46 PM
skaliwag's Avatar
Default RE: Skydrill Build Thread
Lookin' good Brian. How are the o-z's counting up?
Old 10-15-2007, 10:17 PM
rainedave's Avatar
Hallelujah Brian! Looks great. It's twelve days until the 27th. You've got plenty of time. Think it can be ready to test fly this weekend? or, at least test run the TD.
David
Old 10-16-2007, 03:27 AM
jlkonn's Avatar
Thanks to this thread I ordered a Skydrill and DNU from Select Hobbies last week.
Came yesterday witht he mail.
Very impressively wrapped in Tyvek type wrapping.
But...
I'm afraid to open the package!
[sm=frown.gif]
If I do I'm scared I won't be able to help myself and I'd have to drop everything and start building one of them!!!!
JLK
Old 10-16-2007, 06:32 AM
My Feedback: (23)
av8rsodt's Avatar
Steve - I haven't had a chance to weigh the airframe yet. The rudder / elevator was just posed for the picture (you know how it is, always scotch tape together before closing shop). I will weigh tonight when I get a chance.
Hoping to get the wing done by this weekend so I can start covering.
RD - I am up for testing the TD this weekend if you are. I believe I have everything needed with exception of fuel. Actually, I would like to test 2-3 TD's to see how they run... it has been awhile.
Brian
Old 10-16-2007, 06:49 AM
rainedave's Avatar
If you let me borrow one of your TD's for my Sure Shark, you can use my fuel... I guess.
Actually, we should go to Archdale or King and get another quart of Sig 1/2A fuel. I'm running low, but I have enough to run the TD's. I'll call them to see who has it in stock.
David
Old 10-16-2007, 05:41 PM
  #31
Looks great. Ordered my kit today. Look forward to the rest of this build thread.
Old 10-16-2007, 09:01 PM
  #32
Thought I'd share a few pic's of my Sky Drill. I don't know if they are in order or not. I think one shows the nice clean lazer cut parts. Many parts are stages for the pictures. I'm using a .06 paw diesel motor so I'm putting a exhaust pipe from th motor muffler inside to the back or the plane. It comes out just in front of the tail wheel. Other than the short plastic tubing on each end the main exhaust pipe is alumunium tin foil. I can't take credit for it, I seen a post from someone else that did it here on rcu. Last weighing was 9 oz and I still had to cover it, add wheels, fuel tank,and radio, and a little top sheeting. I still have trimming, sanding, etc to do.
Terry
ID:	784482   Click image for larger version
ID:	784483   Click image for larger version
ID:	784484   Click image for larger version
ID:	784485   Click image for larger version
ID:	784486   Click image for larger version
ID:	784487   Click image for larger version
ID:	784488   Click image for larger version
Old 10-16-2007, 09:40 PM
  #33
skaliwag's Avatar
Neat idea with the exhaust.
How it it balancing?
What size tank are you planning on?
How long did you make the L/G legs?
Have you checked the weight?
Old 10-16-2007, 10:05 PM
  #34
I haven't checked it for balance under the wing, but ist almost balanced resting on the landing gear. I'll use as large of a tank that I can fit in it. I checked a 2 oz angle tank and it doesn't fit the normal way but I don't know why one can't be used on its side. Landing gear took about 10 mins to bend. As it sits, its about 9 0z. Still needs radio, fuel tank, wheels, covering and a little top sheeting. I think thats about all it needs.
Old 10-16-2007, 11:00 PM
  #35
skaliwag's Avatar
Tank shot.
Old 10-16-2007, 11:06 PM
  #36
Wow, i'm glad to find a kit of this magnificent plane!!!
I build mine form the plans and is the best 1/2A plane I have ever flown, sure is worth to kit it.
Some friends here liked the plane but is kind of hard for them to build from plans.
Anyone willing to sell me a canopy??? is the only thing that my plane lacks and for sure will like to put one on it.
Saludos.
Old 10-17-2007, 12:17 AM
  #37
skaliwag's Avatar
Ola Bolio,,.... Thank you for the compliment on the Skydrill... Do you have a picture of yours?
I can help you with the canopy but not with any ARF's for your friends. Don't have a China connection.. I believe Global (Hobby People) was having ARF's made in Mexico at one time.
Old 10-17-2007, 10:34 AM
  #38
I posted some in this thread. http://www.rcuniverse.com/forum/fb.asp?m=5989155
I wasn't thinking in ARF's my friend, kit would do the trick for my friend. Sadly my english is bad and sometimes I can't said exactly my toughts.
What I was trying to saly is that scratchbuilding is hard for my friends, they don't want to cut all the pieces.
Can you help me with the canopy???
I can bought a kit and you include 2 canopys
Saludos.
Old 10-17-2007, 10:50 AM
  #39
skaliwag's Avatar
Hi Bolio... You model is a "Kaotic" by PTUlmer . The Skydrill is a variation of tha Kaotic.. A little tuck here, a tiny squeeze there to make it Kit friendly. The Skydrill free plan is on PT's site though.
http://www.ulmer-rc.com/dotnetnuke/default.aspx
Old 10-20-2007, 07:58 PM
  #40
Hi again. Well I at the point where I have to start thinking about the center of gravity of my sky drill. Well it appears that with the .06 paw diesel I'm using, it's now nose heavy. Evey if I was going to use a 049 I'd still have problems fitting everything in. It would be real nice if I could use a smaller battary pack.
Where do you battary at. Is it smaller than most? The one I have is the size if 4 double A's. It would be nicer if I could use 4 triple a battarys as they would fit a lit better. Since I'm nose heavy I have to move the battary back but I don't want it to interfer with the servo's. Any ideas? Terry
Old 10-20-2007, 08:28 PM
  #41
ORIGINAL: tewitt1949
I bought a 9 volts rechargeable battery at Radio Shack and used four of the 7 cells inside that battery, they have a 150 mah capacity and I can make 5 flights before recharging, weight really light.
Saludos.
Old 10-20-2007, 09:05 PM
  #42
skaliwag's Avatar
The Proto has 1/2 of one of these... Laying under the tank.
http://www3.towerhobbies.com/cgi-bin...36&I=LXGBL7&P=
If it's nose heavy a small battery can be poked in aft of F-3.
Old 10-20-2007, 09:52 PM
  #43
Skaliwag, That's a 9.6 volt battary. Isn't that too much voltage for a receiver that normally uses about 5 volts? Isn't that the same as a transmitter battary? Terry
Old 10-20-2007, 09:54 PM
  #44
Sorry I went back and read your post. 1/2 of that would be Ok. Where do I get one?
Do you have a link?
PS. Did you get my email I sent this morning? Terry
Old 10-20-2007, 10:36 PM
  #45
skaliwag's Avatar
I played with the Radio Shack 9.6v rechargables a while back and found they do not like to be Zap charged. Also found a 5 pack system worked the best, small servos suck up the juice.
Old 10-21-2007, 08:57 PM
  #46
Steve, Do think you have the small battarys that I need for the skydrill? Half the size of the one you posted above. Terry
Old 10-21-2007, 10:02 PM
  #47
skaliwag's Avatar
I will look when I go to the shop in the morning.
Old 10-21-2007, 11:04 PM
  #48
rainedave's Avatar
The best 1/2A rx packs I have found are the 370mah NiMH packs from Radical R/C. They weight one ounce and cost $13 with connector. I have done as many as eight flights on a charge with plenty left over. That's with two HS-55's and a 1oz tank. I like to play it safe, but I'll bet you could easily get ten or more flights on one charge. I love these packs.
They are the 7th, 8th and 9th ones down in the list:
http://www.radicalrc.com/shop/?shop=...19&cart=721828
David
Old 10-24-2007, 08:33 PM
  #49
Well,.... here are a few of my latest pictures of my sky drill. I have a few more things to do it but its about 98% done. I'm waiting for the battary to arrive from Radial RC. With the diesel it is nose heavy so I'm going to have to move the battary back somehow/somplace. I think if I move it behind the servos, it will be tail heavy. I'll try it and see. This is a nice kit that I got from steve at select hobbies. It has taught me how to build light. I still have a lot to to learn but who says you can't teach an old dog new tricks. Terry
ID:	789773   Click image for larger version
ID:	789774   Click image for larger version
ID:	789775   Click image for larger version
ID:	789776   Click image for larger version
Old 10-24-2007, 08:42 PM
  #50
skaliwag's Avatar
Plane looks just great. You're gonna have a hard time getting it of the pebbles with those wheels though....
Love the graphics.. Do tell where you got the font and how you "waved" it..
I would seal where the Pipe goes through the firewall.. PAW's are slobery.. Perhaps someone here could suggest what to use?
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
