"1/2 A" & "1/8 A" airplanes These are the small ones...more popular now than ever.
Servo Help
Old 09-04-2007 | 07:41 PM
Default Servo Help
I know this isn't 1/2a specific....but this is the only forum I post to and I know that there is a wealth of knowledge with everyone here. I crashed a plane last year and I just now got around to fixing it(it really wasn't my fault, rog was standing next to me, so we will blame him). I went to check the servos(Futaba S3004) and the elevator servo when operated continues to just run....for instance; I pull back for up elevator and the servo never stops, I push forward for down elevator and the servos never stops, it continues to run(no control horn hooked up). I pulled it apart and from what I can tell the gears look fine, nothing apears to be stripped. The servo also sounds fine no grinding or anything. I will try and post a few pics of the insides. Any ideas?
thanks
-Bill
Old 09-04-2007 | 07:58 PM
Default RE: Servo Help
Well, I dunno why the inside appears to be fine when you checked... The Futaba servo you speak of is a standard run servo and doesn't cost anything to replace in its entirety. The problem is that 1. either the little limiter attached to the final output gear has broken off, or 2. the little electrical pot that is attached to the final output gear has unattached itself from the final output gear.
Take the servo completely apart -- again, and re-pack all the gears. Be sure to fit the final output gear (this gear is the one in which the servo horn attaches to) properly to the little electrical pot (an electrical pot is a device with a variable turning radius, much like a guitar volume knob). The final output gear actually sits directly on top of this pot; the pot works in conjunction with the servo motor -- it tells the motor to stop spinning once it reaches the full point in either dorection. I have had this happen many times. Trust me, your problem is exactly this.
P.S. The final output gear is notched so the pot only has one true way to fit. Be sure to center the pot with a pair of needle-nose pliers before attaching the gears. If you don't you will have lots of motion one direction and little the opposite direction.
Old 09-05-2007 | 01:08 PM
Also, I forgot, make sure the "pot" is pulled up. When you have the case completely apart look at the pot bottom end; it is wired to the board with copper strips -- these tend to flex downward and make the pot lower itself. Simply pull up on the pot to re-spring the copper strips.
