engin I,D
AK
engin I,D
Howdie gents. Maybe some one here can help me I.D this engin? I thought it was an0.010 then I saw one on E-B-- and they said it was a 0.020 off of a cox heili. Its the one with the yellow back plate, the baby bee is for size reference Thanks hkbii.
RE: engin I,D
As a kid I used cut and drill a thin metal plate mount that went between the crankcase and the plastic product engine backplate with a gasket on both sides. That worked well enough and usually lasted as long as the plane, but it was a bit flexible and the backplate had to be mounted to the crankcase from the other side of the firewall. Anybody should be able to do better today.
