TWIN FEVER !!!
#76
TX
RE: TWIN FEVER !!!
For anyone but CP, Fast & Final maidens might not work,
but given the speed that CP builds planes, and the speed he flies them, it could work out for him.
Each weekend he could show up with a crate of 20 fuzes & 25 wings, who cares how many make it back home if they fly fast enough.
Oh, now that SR77 is here,
CP could consider a Mid-Engine & Shaft layout to help with balanceing his TwinFever,
aint that right SR? [8D]
#77
RE: TWIN FEVER !!!
Progress has ground to a halt while I scrape off some uncured resin. Working with small batches and not being real carefull with mixing ratio and mixing technique probably are the main causes. Anyway, I've been working with a single edge razor and scraping the goo from some spots. Once the top side is all glassed, then the under belly can be worked on and this sucker won't be that far from being RTF.
#78
RE: TWIN FEVER !!!
ORIGINAL: combatpigg
MJD
#80
TX
RE: TWIN FEVER !!!
"I think you should try it now, and if it works okay, you know it will fly even better once you cover the outer panels. Might save you some time..? "
Why not?
That amount of wing area worked ok for the F104 Manned Missile, right?
I think you actually have more than the Starfighter area without the pannels
Besides, with the Duct Tape cover he was using in the other pic, the rest of cover job wont take long.
Why not?
#81
MN
RE: TWIN FEVER !!!
CP
Has this thing flown yet? you get a lurker all excited and then leave them out in the cold, hanging for info.[]
My name is Tim, by the way. You are a great builder. I haven't built in a couple of years but I just bought RD's SureShark to get me back into the little planes. That's how I started many years ago.
Would love to get an update on the TWIN.
Tim
Tim
#82
RE: TWIN FEVER !!!
Hi Tim, thanks for the compliment...but I'm not a great builder, I just do a great deal of building.
Look up Tom Dixon, Windy Urtnowski, Phil Granderson, Bob Hunt, Paul Walker, Dan Rutherford, Howard Rush........for guys who not only build pretty but very light. In the pylon and pattern arenas there are dozens of others who are masters at the craft. Comp 3D has its' own budding crop of geniuses. Most of the excellence in this functional art is competition driven......for those who down grade competition, they have that to thank for the excellent array of sport models to choose from that use advanced techniques and design wisdom..
Anyway, the twin is getting the same treatment on the bottom side that it did on top. I need to sand the fillets and apply at least one primer coat of epoxy, then glass the bottom and bring it up to the same level of "doneness" that the top side is at. Then the whole works will get treated to a nice coat of 2 part primer, more sanding, more primer, then top coat the whole enchilada with flat black Klasskote. Whew!
#86
TX
RE: TWIN FEVER !!!
Sweet lookin bird.
But ohhh man, I could lose orientation while taxiing that thing to the runway.
You get some new cyborg eyes installed, or what?
#87
RE: TWIN FEVER !!!
I hate to spoil the looks of it, but it might not be easy to fly with the "CIA" paint scheme . There was a sketch of a Airforce version, not as cool but practical. I think white on black could be treacherous too. Another problem is I'm used to having the highlights on top which ruins the looks even more. I'm going to trade noted with Funkworks in the speed forum and see what he did on his.
#88
RE: TWIN FEVER !!!
I was thinking about 1/2A's and pitch speed and picked up a couple of MA 5.5x4.5, so's I can trim them down to 4.something and check them out as candidates for small zippy 1/2A models. Not sure they'd do better than a 4.2x4 APC though.
MJD
#89
RE: TWIN FEVER !!!
Combatpigg;
Black and white should work well, it's been used for rockets punching through clouds, and should do the same for that cooool looking jet you have there.
That sketch shows something on the back of the bird, any info on that?
#90
RE: TWIN FEVER !!!
The blackbird was redesignated the M-21 when carrying the D-21 recon drone (which is what that doodad is that's mounted on it).
More info on the D-21;
http://www.wvi.com/~sr71webmaster/d21~1.htm
#91
RE: TWIN FEVER !!!
DT, thanks for linking us to the history behind the little guy riding piggy back. What a sickening story about the pilot who was killed by this pipe dream that was most likely concocted by guys who get air sick from being on a 6 foot ladder. All this time I thought the thing riding piggy back was just an artists' concept
I've settled on white stripes on top......and the realization that this plane needs a launcher contraption. There is no way to throw this thing, unless I can get someone from "Labor Ready".
#94
RE: TWIN FEVER !!!
ORIGINAL: digital_trucker
Why not use rocket motors and launch the thing that way...off a rail?
<JD
#95
TX
RE: TWIN FEVER !!!
How about mounting the Drone on a piggyback rail on the TwinFever,
that mounts on a piggyback rail on a .40 Trainer.
Have the .40 take them up & let them go.
#97
RE: TWIN FEVER !!!
ORIGINAL: KidEpoxy
Armchair consultants.. sheesh!
MJD
#98
MD
RE: TWIN FEVER !!!
ORIGINAL: MJD
Or.. for test flights at least have a buddy piggyback up the twin on a jerry-rigged rack?!? Seems like both a sensible and cool-fun way to buy yourself an opportunity to figure the thing out before anything unwanted happens.
#99
RE: TWIN FEVER !!!
Those are all great ideas! I thought about using a simple Hi-Start, but figured that the props might get tangled in the line. I think a skid that isn''t too complex will be fun to try. The ultimate goal is to get some air time and if lucky, take the plane home and make patterns off of it to build a hollow balsa and Monokote copy.
I haven''t checked the model for buoyancy with the engines running yet, one of them is brand new and needs some TLC. Side jobs have cut into building time lately, but this is the time of year to get a jump on yard work before jungle season begins.
#100
RE: TWIN FEVER !!!
Pigg........
That''s awesssssssoooooommmmmmeeeee......
I have one 1/2A twin now & I
have another in the works.
Twins are great, but 1/2a twins are
twice the fun.
Good Luck with your new toy & we want
a flight report asap!
Johnny C!
twice the fun.
Johnny C!
