Graphic Safety Reminder
MD
I'm almost too embarrassed to share this, but if it will prevent it from happening to one of you all, then I'm happy to share.
It's just a Black Widow and a 6 x3 Tornado - how bad can they bite? Well, here's what happens when reach through the prop to pull off the glow plug clip. Not for the squeamish... open at your own risk, etc...
There's no place in our hobby for complacency, OK guys?
My Feedback: (50)
CA
RE: Graphic Safety Reminder
I've done similar...
I was tweaking the needle for max RPM before launch, with a screamin' dual port reedie and a Cox grey prop and not paying attention. I simply stuck my middle finger into the prop arc, and it took about 3/16" off the tip (of my finger, that is). It did grow back, but the scar is still very visable. I can still remember just about everything - except for the prop size . I strongly remember the sting of the alcohol/nitro! It was over 40 years ago.
Arlen
Arlen
Black Widow mounted on a test block clamped in a vice in the shop; MA 6x3; reached thru the prop to adjust the needle -- who knows why??!!
Very similar to yours, but missing the parts between the cuts, mostly on the shop wall. The only part feeling worse than my thumb was me for being so DUMB.[]
My advice to everyone is to start drinking.......heavily. That will dampen those knee-jerk impulses to do stuff like that. [sm=tired.gif]
Secondly, those left-over percosets from the last gall bladder attack aren't doing you guys any good at home in the medicine chest, they should always be there in your flight box just in case.
I think I mentioned to you some time ago yet perhaps even recently about my mishap with an APC rotating razor blade 8X4 on my .46LA??????? Let me look for that Email.
I don't know if it would have helped at all in this case but I ALWAYS sand off the flashing from the edges of any prop I use. Part of it is for efficiency and a much bigger part is to remove the razor like flashing residue that can do this sort of thing.
MD
Well, ummm... even though all of my props are de-flashed, the ole Black Widow was running backwards and it was the trailing edge of the prop that got me!
I think what caused the lack of concentration was the fact that the little booger kept starting backwards and I was getting frustrated. [:@] I am proud of the fact that I was getting one-flip starts though (even if it was backwards).
CP - you never fail to crack me up!
PBJ, That was one of Blutowskis' [Belushis'] lines in Animal House. Another line that I love in the same movie from Dean Wormer, "Fat, drunk and stupid is no way to go through life, son".
I think both lines were delivered to poor "Flounder". What ever happened to that guy? He kind of looked like Larry Mondelo on Leave it to Beaver.
LA
Okay guys, ya wanna play the chopped up finger show? How's my left pinky for ghastly? No, I didn't lose it to an airplane engine, but to accidently getting caught in a go kart chain & clutch. Turned it into ground meat in 'bout 1/2a second. Pun intended. Musta been shock, but it didn't hurt at all! Maybe there weren't 'nuff left! Still have the knuckle. It works too. Freaky stuff man.
Frank
Frank
WA
ORIGINAL: BMatthews
somegeek
TX
Last one I got was from turning the needle... I was even standing behind the engine is what gets me mad. Too much knuckle sticking out for too much rotation, and Pzzzzzzth! Took a 1/4" circle of 'me' off my knuckle: One of them really shallow, really bloody divots.
By my recolection, I figure I've gotten worse lacerations from APC props just getting the plane into & out of the car than from a spinning one <knock wood>. There is your complacency, lax procedure cause there isnt even any fuel residue in the engine and SLICE- you find out the hard way how much methanol is on your toolbox rag when you try to stop the bleeding with it.
Chopped fingers are a right of passage with IC aeromodelling....
I can feel your pain brother, those injuries tend to bleed like a stuck pig, hope you regain all feeling in the finger.
Not just for IC anymore.....
Did I tell you the one about the time I wired up a small out runner to the ESC? decided to check direction of rotation, by holding the little stick mount (no stick attached) in my hand. APC 11x8 sloflite.
Well I was so happy to get the rotation correct decided to do a little blip of the throttle in celebration , well it torqued right out of my hand and rolled across the top of my hand slicing up the tops of my nuckles of first and middle fingers ans twisting up the esc wires faster than a safty wire plyer.
Then the time I decided to hold a td .020 in my hand - in my kitchen.....sounds harmless enough, eh?
Had a good grip on the case between the thumb and index finger. started her up. Immediatly started spinning 19-20 grand and pulling pretty good, increased my grip - all was good, Leaned her out, have a tiger by the tail - but then it started getting hot - hmm? and it got hotter, and my fingertips were sending PAIN signals to the grey matter - what to do? can't let go? can't hold on? frantically reached for the fuel line with the other hand and it seemed like an eternaty before it seperated and I could think about my stupidity - and grab an icecube[:-]
Hey Luna, what kind of small hub prop is that?
MD
Oh my gosh, yes! My whole hand was covered in blood in the time it took me to police everything up and get to the house - literally a minute away. It's a good thing my wife can read my face cause if she would have judged the extent of my injuries by the amount of blood on my hand she probably would have been much more frantic!
Holding a running engine in your hand? Well, er, ummmm..... they do get a bit warm don't they? [X(] (Not recommended folks!)
[sm=thumbup.gif] seems all the 1/2a'ers have those multiple laceration scars on at least one finger. I cant help it, I had to chuckle a little when I looked at the picture and then at my own fingers. Poor Joe! my last one, just two yrs ago took forever to heal. hurt like hell too , didnt seem like the first ones when younger took that long to heal. I think I even said the "f" word when I splatered blood all over my tail gate. I had about a ten mile ride to get stitches, that remeinded me why they say to take a friend flying, I could have used a driver that day. I think I said the "f' word several times actually.
ORIGINAL: RocketRob
I realize you can just use a piece of fuel tubing over the prop screw to take up the gap, but some times with APC's, that hole just isn't in the centre. But these spinners index to the recess in the front of the prop which is indeed aligned to true centre.
regards,
Mike.
Edit: Don't attach the drive washer when your filing down the spinner with the drill, just mount the spinner to the modded crank and your good to go.
ORIGINAL: Luna_Rendezvous
MN
I know I'll prolly be tagged a wuss....But I like to hand start all my models if possible...I've found a good archery glove can be great http://www.cabelas.com/cabelas/en/te...equestid=83757, and you are still unencumbered TX wise, and its easy to wiggle your fingers out of and just let oit hang from your wrist if it bothers you flying.. WOW what a link!!!
Yep, Mine was a Norvel .061 AME with an APC (Another Perfect Cut) I counted at least 5 slashes in my finger from that lil booger. So what did I do.. I wrapped it up with a wet paper towel then held it there with a handfull of rubber bands (wing hold downs), and continued playing with my toys. About an hour or so later a buddy comes up and says, "what did you do to your finger?" I replied, "I dumb A##ed myself and got my finger in the spinning prop." I then prodeded to show him the injury by his request. He then states what I really already knew, "You need to go get some stitches"[:@] So I have to stop playing with my toys long enough to stop bleeding.[:'(]
Does nitro fuel burn hot enough to cortorize a prop wound[>:]
