.15 pitts muffler
ON, CANADA
RE: .15 pitts muffler
I picked up a Bisson Muffler two days ago from a local hobby store http://www.hobbyhobby.com/ the cost was $29 I'm using it on my OS 15 in my L-19 Bird dog.
Here's an alternative that might do the job:
http://www3.towerhobbies.com/cgi-bin...?&I=LXCA87&P=Z
But I'm puzzled by the comment above -- I've never heard that pitts mufflers reduce power, and I don't see any reason why they should.
Jim
Jim
ON, CANADA
I hope it's not a huge loss of power[] my L-19 called for a 15-20, i went for the OS 15LA and will use the pitt muffler to save cutting up my cowl. I'll post my thoughts after the maiden flight.
Thanks, rywil
Thanks, rywil
My Feedback: (66)
run it on a test stand. just use a small piece of wood and cut it out with jig saw. this will also help with break in if any is required on your motoe. after broken in get a reading with the stock muffler with baffle removed then run it with the pitts muffler and lets us know the results. i bet you lose about 500-1000 rpm with the pitts.
Geezzz ... where did I see that photo from Joe Wagner, where he made a muffler out of WOOD and attached it to an engine, and it worked? Oil soaked, but it was working...
