plane for asp 15
RE: plane for asp 15
I've been flying a 1/12 scale Arsenal VG-33 that was built from RCM plans for several years on a TT .15. Although RCM magazine is defunct I understand the plans service is still in business. Gus Morfis does plans for a lot of small warbirds. If you are going to do a warbird go with one of the inline engine birds like a P-51, a Spitfire, or a P40. It takes a bigger engine to pull a similar blunt nosed plane around. I run a .25 on my Pica Zero. unless you get carried away with detailing the little fuselages aren't much more difficult to build than plank profile fuselage. The ME 109 was built from plans that were a Model Airplane News freebie. It was modified with a thick airfoil that didn't work out due to being too draggy and needed a bigger motor, but the standard thinner wing should be just fine. Both were easy strait forward planes to build. I didn't get a picture of the Morfis P-40 before I sold it to a buddy of mine.
This may not be a warbird but this is a great flying little plane. It is called a Hyper bee and your engine would be perfect. http://aspectaviation.com/ Go to the kits section and click on Hyper Bee.
