Cox Conquest Piston Liners
RE: Cox Conquest Piston Liners
The man I buy my Brodak dope from (he's a great guy; very helpful over the phone and ships stuff fast) has the Conquest P/L sets on his web site for $29.52.
Scroll down to Cox Parts:
http://beseenontheinternet.com/VAHS/...ccessories.htm
David
David
ORIGINAL: gcb
I'm afraid mine is a box stock Cox version.
George
George
Nuttin' wrong with that! The Conquest is a rocking little motor, even in muffled R/C guise!
#31
If you are interested in me looking at your engine and would like me to go thru it and let you know what you have let me know.
Ron Young [email protected]
#32
I have what ever you need for your Conquest 15 and I am also getting set up to repair Conquest 15 engines that were made by Cox,K&B and RJL. Also Randy at RJL will refer all repairs to me so if you need ANYTHING for a Conquest 15 I will have it, I also will have A.B.C. Piston and Liners.
Ron Young. [email protected]
#33
Are the Piston and Liners you purchased the old ones that Cox made and if so they are made od centered iron and very hard to break in.
Ron.
Ron.
#36
ORIGINAL: MJD
That's too bad. I'll buy it if it's depressing you...
MJD
MJD
George
#39
ORIGINAL: combatpigg
MJD, no day dreaming until you finish your OPS projects [>:]!!
MJD
#40
The A.B.C. piston and liners I now have will fit a Rossi MK I and MK II you will need to use your Rossi rod, if you have any questions let me know.
Ron.
Ron.
#41
I received my ABC Conquests by Ron Young over the holiday - actually before but had'nt had tome to run one up.
Ran one last night and got a few ounces through it. I'm running a rich two cycle, I find if I lean it just where it breaks into a twocycle I can richen it up a bit more and it will stay two cycle.
A few more cycles and I'll lean to peak [8D]
Running the RC carb and muffler and a 7x5 apc on 15% nitro/castor fuel.
I can't praise Ron highly enough for the quality of his workmanship!
#42
ORIGINAL: RocketRob
#44
I am getting 19,100-19,200 on the apc 7x5. I think it really wants me to loose the funky muffler and perhaps a smaller prop to better advantage the lower recripricating mass. I think I'll run her with a 6.5 x 5 uncapped - can't really get much louder.
#48
Are the P/L he has Iron Pistons or the old centered iron, unless they are from K&B,RJL or myself they are centered iron and not the good ones.
#50
GA
I got one of these from Devious Dave a while back and have recently pulled a kit off the shelf for it. I've got a header sticking out the back, but that's it. Is there a pipe or something I should be looking for?
