The Great Glow Plug Run Off!
ON, CANADA
RE: The Great Glow Plug Run Off!
ORIGINAL: Yuu
Nice work, Graham. Beautiful presentation and method. I love the hypodermic drip measuring description, and the fuel mix description. But I got confused. First question: You wrote that you removed .045" from the bottom of the head; I assume you meant from the Mecoa head, right? Second question: You used Permatex anti-sieze on the 'plug' threads; but my Nelson plug seals against the bottom of the Galbreath head, and the 'plug threads' are not in the combustion chamber, so the anti-sieze is just to get the Nelson plug out of the Galbreath head, right? Third question: You use 'four' gaskets on the Galbreath head [?] and it runs best: but doesn't that 'Increase' the volume of the actual combustion chamber, thus reducing compression [?]' erasing the previous 'gain' in compression? Last question: Using anti-sieze on the plug threads; why not use anti-sieze ALSO on the Galbreath head-to-cylinder threads AND on/between the four gaskets... to reduce/adjust cylinder volume? None of my questions relate to anything about the 'squish band', which may involve some of the answers to my questions. Anyways, your report got me thinging again. Thanks.
The use of the anti seize with the Nelson plugs is simply to ensure that the plug does not gall in the aluminum head and hopefully permits the plug to be removed when needed.
Yes, using multiple head gaskets with the Galbreath head does in fact reduce the compression ratio (among other things).
Anti-sieze on the head threads and on the gaskets. Intesting idea. It may have some benefit on the head to cylinder threads such that you don't the the head siezed in the cylinder but would have no benefit on the gaskets/shims themselves.
Every time you add another or take away a head gasket/shim you are not only adjusting compression ratio (as you and others have noted) you are also changing many other variables - squish band thickness and plug depth to name two. In our small engines and for our use of sport flying it is one of the simpler ways to make these engines a bit more useable. My goal when I started this testing wasn't to get the ultimate in performance but rather to learn and to dispell some of the old wives tales.
cheers,Graham
ON, CANADA
ORIGINAL: unattainium
I have a Galbreath head and feel that it could be improved a little to make it more of a trumpet shape by having the head extend over the underside of the plug and only leave the element exposed.
A regular glow plug could be converted to a turbo type by machining a taper on the end and being very careful not to damage the element.
Adding head gaskets changes the squish band thickness and consequently is not the best way to change the compression ratio. A head for each C/R would be better or possibly havong spacer washers which covered the squish band. Heavy anodizing on the combustion chamber would reduce heat flow into the heat and slightly improve performance by improving efficiency. My guess is that the Mecoa head ran smoothly because of its rough shape which generated a lot of turbulence and discouraged detonation. Using a more regular head with an optimal squish band may provide the power of the Galbreath and the smoothness of the modified Mecoa.
An interesting subject to some and quite boring for others. To each his (or her) own. We need each to pick our spot (desired performance) and test fuel, props, plugs to get as close to that as we can.
Lapping the taper on the Nelson/Turbo plug and the seating taper in the head could ensure a good seal, a bit like lapping poppet valves in a four stroke except that a dummy plug with no thread would be needed for the head when turbo plugs were used. A custom made collet would do the job with the Nelsons...
Finally a tip about measuring combustion chamber volume we used to use back when i was involved in building high performance race engines. Make a plate of clear acrylic which covers the chamber and drill a hole in it. Clamp it to the head with some grease as a seal and use a burette to fill up to the hole and record the amount of liquid added. This method avoids meniscus and leveling errors. I have several Medallion 09s and a TeeDee 09 and am short of good heads and have a project to make heads for them using Nelson plugs.
cheers, Graham
ORIGINAL: GrahamC
Yes, much like the "peep hole" style of plug and head. Irecall that Norvel made an adapter button for their engines like this - Ihad one in my hands for a while but never tried it, Itraded it with a bunch of other stuff some time ago. I may try and make one or somthing similar to try.
Iskandar
ON, CANADA
Yes indeed that is a problem and one I recognized early on. I think it was an early attempt to "optimize" head/combustion chamber/plug etc and quite likely the grandfather of the idea of the Nelson and Turbo plugs.
I have picked up three of the new Merlin Norvel type plugs put haven't had the time to test them. Some others have posted a few comments but as of yet Ihave not seen anything negative. My first impression is that they are well made and fit quite nicely.
The plugs have steel bodys rather than aluminum which is quite interesting. I read a comment someplace by someone with a lot of experience in such matters (Dale Kirn perhaps?) that platinum does not like or care for aluminum - reacts or somehow oxidizes (I can't remember the content of comment) which is why most manufacturers used steel bodies for their plugs - except Cox and Norvel. I have not be able to verify the comment but makes me wonder if the Merlin plugs are made of steel for that reason or for simplicity or ease of manufacture?
cheers, Graham in Ottawa Canada
ORIGINAL: GrahamC
Yes indeed that is a problem and one I recognized early on. I think it was an early attempt to ''optimize'' head/combustion chamber/plug etc and quite likely the grandfather of the idea of the Nelson and Turbo plugs.
I have picked up three of the new Merlin Norvel type plugs put haven't had the time to test them. Some others have posted a few comments but as of yet I have not seen anything negative. My first impression is that they are well made and fit quite nicely.
Anyone have a look at Doug Galbreath's web site recently? He's making a .020 head (actually, he'll machine your burned out head) that takes the insert part of the Nelson "Glo-bee" plug.
http://www.the-printer.net/DookCat.html#coxconv
Also, Bernie from coxengines.ca has announced he'll be making .020 Cox heads.
Iskandar
#31
PA
I want to try the turbo flatcoils out on my black widow and teedee 049`s with the "new" teedee piston/cylinders, has anyone else tried these configurations yet?
I`m going to place orders shortly, since the" new" piston/cylinders are available, its time to break out the carbed 049 and give it a revival run at the sky
#32
I don't want to spoil your joy, but there are no new piston/cylinders.
There are only some modified surestart cylinders. The modification concistst of removing the slit and then trying to deburr the inside. Mine was so rough and sloppy in the lower part of the cylinder that I don't dare to run it.
There is more info [link=http://www.rcuniverse.com/forum/fb.asp?m=10492710]Here[/link]
#33
I have a TD 09 high compression head modified for Nelson plug by a friend of a friend. At peak, it is about 200 RPM better than the stock head and seems to be more consistent when flying maneuvers.
#35
Mr Cox, Merlin make flatcoil(glowbee style) in regular 1/4-32 #2016 #2016B, turbo #2017,#2017Band Nelson style #1125B,#1125C plugs, as well as the 1/2A insert with flat coil -#2019B,2019C
http://www.merlinglowplugs.com/Aircraft.html
Stewart
Stewart
#36
ORIGINAL: SGC
Do know if the Merlin NELSON style plug is a drop in replacement for the original NELSON plug (11/32 x 32)?
andrew
#38
TX
My experience with Glow Bee pligs was not all
that good. Power seemed to be down on lower nitro ( less than 25% )
and not very consistent. With nitro content over 25% and two shims
they would do well and outlast the hi comp Cox heads. RPMs were
not as good as Cox heads.
Ralph
Ralph
#39
Andrew,
From my correspondence with Merlin, the Nelson style plugs are the same on the thread/taper as the original but has the same hex/top construction as a 1/4-32 plug so a regular glowdriver will fit them, I personally havent purchased there nelson plugs as of yet. Ive only got the 1 VA mk2 and still useing up the spare nelson plugs I bought from Larry.
#40
ORIGINAL: Andrew
Stewart
andrew
ORIGINAL: SGC
andrew
I should get a few to try.
Incidentally, check this out:
http://www.freepatentsonline.com/7205506.pdf
Do you think it'd fly???
Iskandar
#43
ORIGINAL: Mr Cox
Wow, I had completely missed flat coils in turbo plugs.
I didn't think there was any advantage to the flat coils anyway?
For some reason, they never caught on with F2D fliers, though. I wanted to try some, but they're not made any more. I have some Merlins coming, though.
You can still get Nelson flat coil rewinds from Russia, though:
http://www.rusengines.ru/prc.php?lan...7.67&EUR=39.51
Not cheap. And they call them "suppositories".
Iskandar
#44
TX
Hello all. (When reading my posts please remember that I sell Nelson plugs, believe them to be a great value and pretty much the long time benchmark for durable, high performance glow plugs.)
That said . . . Iskandar, I had not heard the rumor that Nelson was not making flat coil plugs anymore. I have them in stock and was quickly supplied by Nelson the last time I ordered.
So I wrote Henry Nelson and inquired. He immediately wrote back saying, "Not true". And he has lots of the bodies needed to make the plugs.
Thus, while there are more choices in plugs than a few years ago, the Nelsons are still the first pick of both many competitors and value conscious sport pilots.
#45
Hi Larry
I should have checked with Henry, I suppose. I was going by Dave Shadel's web site:
http://www.pspec.com/details.asp?ProdID=37&category=
and what I could find on Darrol Cady's web site:
http://www.darrolcady.com/Accessorie...ght.htm#nelson
Glad to hear I can still get the Nelson Globee plugs. I'll go and order some.
Iskandar
P.S. For the rest of you guys.. Larry's website is here:
http://www.kittingittogether.com/
Iskandar
