Whizard by Owen K.
Whizard by Owen K.
Whizard by Owen K.
I have a Whizard by Ace which I got on sale a whole bunch of years ago for about $7, and it is a bit damaged. So need to make a few replacement parts for it.
But... was there an article in some magazine all about them, or was this a strict "Straight to Kit" model?
Wm.
RE:
Whizard by Owen K.
I have a set of the build plans but it is all 1/2 size, so I dont know anything on them that would help..is yours 1 or 2 channels?...I might be able to get a copy, maybe not, problem is I used the back as cover to spray adhesive on another project, so I'm not sure they would go through a copy machine, still sticky....I could double size parts of it at work after the 5th ....Rog
Except the wing is an Ace foamie
RE:
Whizard by Owen K.
ORIGINAL: CoosBayLumber
RE: <br> Whizard by Owen K.
Rog....
I still have the original plan which came with the kit. Don't need another.
Andrew...
I thought so, but was unaware that an article had been made about the Whizard. Only did a small search. So wonder what is in the text then? My formerly yellow Whizard resembles that as in the picture of the brown model.
Wm.
Andrew...
Wm.
RE:
Whizard by Owen K.
First there was the Whiz Kid published in RCM in 1966.
Then the Super Whiz Kid in RCM 1969. Plan pl-403
Then the Dick's Dream kitted by Ace Radio Control 1971(not published that I know of).
And last the Whizard RCM 1974.
Look carefully and you will see they bear a remarkable resemblance to each other.
Robert
Robert
RE:
Whizard by Owen K.
ORIGINAL: build light
Robert
Robert
andrew
RE:
Whizard by Owen K.
Andrew, Half-A-Hec has an image of it in his RCM Illusrtated Plans. It will tell the plan number.
Once you know the plan number, you might give RCM plan service a call and see.
Robert
Robert
NE
RE:
Whizard by Owen K.
Guy's,
I will check my RCM plans book and see what the plan # is when I get home. If you are interested in an 8-1/2" x 11" scan of the plans I can email it to you as well, just let me know.
Hec
Hec
RE:
Whizard by Owen K.
ORIGINAL: Half-A-Hec
Ok I checked my RCM plans book and it also is listed as plan #547. It calls for an Ace Foam wing as mentioned earlier.
Hec
Hec
#547 is for the Whizard. Do you have a plan # for the Whiz Kid? It should be less than 400 since it was published before the Super Whiz Kid.
andrew
NE
RE:
Whizard by Owen K.
Andrew,
I checked my RCM plans book and did not find the Whiz Kid. I found the Super Whiz Kid Plan # 403. The plans have a nice built up wing or the option of using an Midwest Foam wing and stab. Let me know if ya want a scan of the 8-1/2" x 11" plan.
Hec
Hec
