Super Tigre X.11
Super Tigre X.11
A while back I won this X.11 off the auction site. The first time I ran it fuel was bubbling out around the glow plug and from under the head. I don't have any machining tools (or machining knowledge) so I did what I could by hand. I took a Cox piston, coated it with Wright's Copper Cream and swirled it around where the glow plug washer seats on the head. I also put some on the top edge of the sleeve and twisted it against the head. It worked. It no longer bubbles fuel.
I ran the engine with a wood Zinger 7x4 with the square tips rounded off with sand paper and then re-balanced. I used Sig 25% nitro Champion fuel.
Here are two peak readings I got. It was turning steady just above 19,000 with the needle valve richened a bit from peak. I don't know if these are good numbers or not for this engine, but I thought I'd post them.
David
David
RE: Super Tigre X.11
RD, if you plan on using this engine a lot, make sure that every screw on the carb is locktited and tight and checked often until you're confident everything is going to remain "just so".
I think the performance is good enough here to justify residence in a SureShark, BabyBirdy or a MachNone! I'll bet a ~6x4.5 or 5x5 prop would be worth trying on a fast plane?
Come to think of it, APC has a prop listed for .10 pylon, but it's probably one of those $3.95 specials instead of the $1.83 industrial grade type.
My Feedback: (44)
ID
those are excellent numbers, its still a sleeve bearing engines, give it 20 more tankfuls and you will see the real performance of this little jewel!
i ran one of these on a quickie 200 with a mac's pipe! it sure cleared the local flying site[8D]....
It weighs 170grms, or 6ozs. A lot of that is the muffler. This version has a single ball bearing on the rear of the crank.
So, I guess it's a two-part answer: the performance is good for .11ci of displacement, but not so good for 6ozs of metal.
I will try some other props and post the results. I have a Cox gray 5.5x4 that I'll bolt on next.
David
David
Dave, definitely use castor oil fuel. The conrod in this engine is unbushed. I have an earlier "Bluehead" version which I have broken in well on castor based fuel. The later X .11 like you have now, I had and I ran it on fuel with a castor/synthetic blend and the lower end of the rod wanked out in no time. This was with TopFlite 7X4's
ORIGINAL: rainedave
David
David
Robert
My Feedback: (12)
MT
One of 3 possibilities; (1) You've got a very good running X11, (2) I've got a very poor running X11, or, (3) That is one very "funky" 7x4 prop that you're using. i've always considered my ST (blue head version) to be a very heavy .074 Norvel (performancewise). Also that enormous carb sure don't help make it very user friendly. ............................. George K.
It's more like a 6.875" x 4" with the modified tips.
I removed the restrictor from my carb. It still works well. For me, the trick with all ST carbs of any size is to set the low speed needle so lean that the engine dies when advanced from idle. Then, very gradually richen it one click at a time until it no longer cuts out when advanved. Working the other way - rich to lean - has always been a real pain for me, so I go the opposite way. After the low speed needle is set using that method, I will rotate the spray bar a tiny bit at a time until the midrange is no longer too rich. Then, they work as well as any other carb I've ever owned.
David
David
The ST X-11 engines were great performers. I remember the free-flight guys loving these engines with a straight venturi.
The first one was the blue head version in 1978 and the natural aluminum version was a few years later. Both were avilable in plain-bearing or single BB.
At last count I have 11 of ST X11's.. All of my Natural finish heads are BB and the Blue are plain. I gave my machinist friend a Blue one and he made a diesel head for it
Runs and idles great which really is surprising with the huge black hole that the 15 size carb has. Some of them have a restrictor.
Unfortunately it won't work on the BB version, different all around.
Holy Moly! If I'd have know these engines were that fast I'd have had one years ago. 20k on a 7ishx4 ain't no joke. My only .10 experience is with the OS .10 and that little guy can barely pull the skim off of warm milk. I've got a few more motors in this size range but never used them as other projects got in the way.
ORIGINAL: skaliwag
OK you boys that have the "need for speed" and have one squirreled away somewhere.... Wonder what one would do with a pipe on it and a pylon style (Small dia, Large pitch) prop?
Also ... Anyone know why they made an .11ci (1.79cc)?
It makes a decent diesel conversion too. No record of revs or prop I'm afraid, this photo was taken some years ago. It ran well but the throttle wasn't very impressive. Probably needs a smaller venturi as a diesel.
Yes I agree Dave, the ST carbs are great, but somehow this dieselized setup wouldn't play. I couldn't get any sort of idle, although I admit I didn´t spend a lot of time with it. No doubt it can be sorted out
balsaworks, adapt a AP .061 carb to it, it will work great. I did the same to a PAW .15 last year.
I'm glad to see so much interest in the ST .11s. I thought I heard once why .11s were produced, it had to do with competition.....but I can't remember who, what or why.
