Tiled PDF's
My Feedback: (14)
TX
Tiled PDF's
Ihave tiled PDFs and want to put them back together. Ihave a large format printer and can print out a full size plan. Ijust need to know how to merge tiled files back together to form one drawing or if it is even possible. Thanks in advance for your help.
RE: Tiled PDF's
You can try to make a "copy /paste" from pdf to Paint to create a .bmp/.jpg file. Then you need to check the correct value for the scale.
Sorry for my bad english. I hope you understand.
Regards
Claudio</p>
RE: Tiled PDF's
stick,
This is what I use: http://www.cybersonic.ch/prod_sve1.htm
I am not sure if it is available anymore. The demo download is inactive. It's the best software that I have found for editing black&white raster files. You can easly merge the pages back together. Unfortunately, it is also very expensive.
Gene
Gene
