Diesel pusher
Diesel pusher
Hi,
It's been a while since I've been here, getting a job got in the way big time.
Anyway I'm back at it now, I've got my .049 delta's going again too and I've got ideas to make a pusher for my paw .55
Is there anything I should know before I get going in terms of the engine, If I have it running as a pusher i have a feeling that having the prop driver in contact with the crank case it could wear things out faster.
I thought a pusher would be a good idea as it would keep all the oil off the plane, and the little engine away from front impacts.
1 Post
RE: Diesel pusher
I can't comment on the overall wisdom of this-but it is certainly feasible to do-I would however recommend getting a brass, steel or bronze washer to interpose between the prop driver and the front of the c rankcase-being only a single ballrace engine, the PAW 55 shaft is not axially located the way it is in a twin BB engine, and there will be fore and aft play possible-and hence the chance -in pusher mode-of galling betwewen the prop driver rear face and the front face of the crankcase.Hence a shim washer to take up the fore and aft play and act as a pseodo thrust bearing is a good idea for this particular usage.Sizing/clearance constraints howevrer may mean-depending on tolerances that you have to get one machined up of just the right thickness to restrict movement-but not totally eliminate all play. You want a few (5-10 thou) of fore and aft movement. But your typical; PAW 55 has about 1mm of shaft play. Small Parts has a rtange of thin silicon bronze washers that might do the trick. Ideally, a suitable thrust bearing could be fitted-but you are unlikely to find a commercial one that will fit. Obviously your range of props for pusher use with a PAW 55 will be quite a bit more limited than for tractor use-another point to consider.
'ffkiwi'
'ffkiwi'
