.o49 engines by cox
is the price of .049 right from cox 6.99 hope so have not seen this only on controlines since the 60's is this price right or what do you have to imput
RE: .o49 engines by cox
Yep, the price is correct. I purchased two of them a couple of months ago. I installed an AP carb on one of them.
Price is right, but they are out of stock. No one is too sure when they will be available again.
Pictures! I want a Show 'n Tell about this...
ORIGINAL: air-madness Yep, the price is correct. I purchased two of them a couple of months ago. I installed an AP carb on one of them. |
thanks for replys would like to know more about this engine what fuel is required and what size planes it will propell. thanks for all infornation received so for
Two VERY successful planes for the $7 Sure Start are ptulmer's Das Not Ugly (DNU) and rainedave's Sure Shark. A forum search here will turn up several builds, as well as a few videos. Oh, how could I forget? The Postal Plane Project stickied at the top of the forum page is using a Sure Start as well! [X(] But of course there are many, many more planes that will fly just fine with an .049 reed valve engine, from gliders to trainers, to warbirds and pylon racers... depends on wing area and all up weight of course. For what it's worth, I recently converted a Parkzone J3 Cub to a Cox .049 and at 15 oz, it flew like a scaled cat.
All Cox engines love fuel with medium to high nitro content (15-35%) and a fairly high oil content (20-25%) of which should be mostly castor oil. Hope some of this helps, -Joe |
I spoke with the folks at COX models today, 3/11 -- they expected a delivery of additional engines by mid-March.
I have purchased more than 40 of them at that price. Just ordered 10 of them this week. They were selling for about $29.00 a little more than a year ago. Cox has stopped making fuel (gas) engines. So these are closeout deals, I called about 2=3 months ago they said they still hade 30,000 left but with everyone selling them on e-bay for $10.00 or more plus some hobby shops also selling them some day they will be all gone.
They are a great sport engine for RC or C/L from the factory they spin a 6x3 prop about 12,000 to 13,000 rpm on average. That means you have about 9 = 11 oz of static thrust. With slight modification you can easy get over 15,000 rpm which is about 14 oz of thrust. anything from 10=20 oz should fly ok with them from 100=250 sqin of wing area. I fly high wing plane at 12 =14 oz and the make good fliers. These are good little sport engines, and well worth the $7.00 but almost everyone that I have bought needed the piston reset. You can find out about that by doing a search on cox piston reset. They will usually work without a reset, but you add years to their life by doing so, and if you modify them to get more than 18,000 rpm they won't last a long time without a reset of the piston |
ORIGINAL: lildiesel Pictures! I want a Show 'n Tell about this... ORIGINAL: air-madness Yep, the price is correct. I purchased two of them a couple of months ago. I installed an AP carb on one of them. somegeek |
At 6.95 each this is the cheapest way to get a standard cox glow plug and it comes with a free engine!! I bought four and also stashed some 09 stuf and I couldn't pass on a NIB texaco and NIB black widow each for under $50.00 at a little hobby shop.
Replacement heads that use standard glow plugs are nice idea as well cause the plugs for these little motors are getting rarererererer Hmm may have mispelled something back therererere[>:]:) |
Count me in too! Let's see this thing!
Propjobbill, I love these little engines and have bunches of them. Been flying them for years. If you don't mind sharing your secrets, I am dying to know how to get a surestart to rev up to those rpms with a 6x3. I have polished the cranks, smoothed out the inside of the case, enlarged the venturi, used the galbrath head and still don't get near 15K rpm. It is driving me crazy. I placed an order for a Hyper Color engine ( to get a decent reed engine) some months ago but I understand that Tim Wiltse is going through a rough patch, I wish him the best. Please, I know that many of us would love to here how to get surestart engine up to 18K! If you would be so kind as to share your knowledge. Thanks in advance, Pat (also in Ohio) |
First of all I can't get 18K with a 6x3 prop. I have been using a 6x2 APC prop for those rpm. I'm not sure how much I can get from a 6x3, but I am thinking maybe 15,000. In a few more weeks I will be able to get back to testing if weather permits. The biggest thing that I do is remove the back plate, remove the spray bar, and reed assembly. I chuck up a 3/16 drill bit into the drill press, and drill very slowly from the reed side to the opening where the spray bar goes through. It is very thin and narrows where the spray bar goes through. If you go to fast it will crack the opening. Apply pressure from the needle side of the spray bar when removing the spray bar. If you try from the other direction it will also crack the tube, (I learned this the hard way). I use pliers and caution, I tried pressing the spray bar out. If you apply pressure to the bar without support for the tube it can snap off. After I clean up all the openings from small plastic shavings the drill leaves I reinstall the spray bar. I then carefully open the chock tub in both directions to 3/16”.
I use about 30% fuel for high rpm, I also reset the piston. That’s the first thing I do. Drilling out these openings give me between 2,000 to 3,000 more rpm., and the 6x2 prop gives at least 1,000 more rpm. I find weather, and humidity also make a difference in my rpm. I have had the engines tach over 19,000 rpm, but so far I have not been able to maintain those rpm. It will run in the 17,000 to 17,500 constantly. I have a video on utube of a sure start with a chock throttle. It was done inside a garage on a very cold day after dark with a flashlight about ¾ of the way through you can see the tach at over 17,000 rpm. This is not my best running engine. When the weather gets better I plan on making another video outside in good lighting. I know 17,000 to 18,000 sounds like a lot, but It truly will turn those rpm. With a stock unmodified sure start running a 6x3 prop I get an average rpm of 12,500 = 13,500 rpm. I get a lot more rpm out of APC props than Master Airscrew props. But as I said the biggest thing is drilling the tub and venturi tub out. You don’t have to have a drill press but it helps. I tried it with a hand held drill and broke the venturi tube. The engine really screams after making this modification. After I do this the engine starts better if you drop 4 = 5 drops of fuel down the chock tube before trying to start it. In the video the needle turns with the throttle so it doesn't get the best rpm. I am still working on the chock throttle to get it to work better, again this also will be a warm weather job. http://www.youtube.com/watch?v=KKXThGEl_FE |
I don’t own a 6x3 APC prop I will have to order some to find out what they will turn. I have numbers on about 12 of my cox engines. One of my baby bee engines with an APC 5.7x3 turns 14,300 and another with the same prop turns from 14,500 = 15,000, of course some of them only turn about 12,000 with the same prop. To my knowledge if I did anything to those two engines all I did was to drill out the venturi. But I have no idea what size if i did drill them out.
The APC prop makes a big difference. On every engine I have tried I get more rpm from APC props. I have tried a lot of sizes 5.7" to 11" .049 to .40 engines. and APC always gives more thrust and more rpm. readings. No I don't own or work for APC. I like Master Airscrew props they last much longer for me, and don't break as easy. But for me If it's rpm that I'm after I use APC props. A couple of years ago combatpigg tested cox BabyBee engines with different props . I have copied His results and will paste them here. You will see the APC prpos make a big difference. I learn a lot by listening to these guys that know what they are doing. In his test APC 5.7x3 worked better than any other prop. I like the 6x2 because the plane flies slower and is more relaxing to fly plus it gives more thrust for climbing. This is the DYNO report from COMBATPIGGS' extravagant test facility ! I only have a BABY BEE, and it was running an AP head, on 15%. This engine is somewhere in the middle of it's "prime". It is not set up to go into a full scream, it will rev up to a point where it has a slight "cackle", and if you go past that point it will die. In otherwords, a very baseline BABYBEE, that's best hours are behind it. NEEDLEABILITY MEANS 1click is critical, 2clicks is OK, 3clicks or more in a sweet spot is good/great PROP RPM THRUST OZS NEEDLEABILITY COX. 5-3 15700 8.0 good needle GRISH 5-3 16500 7.8 " " GRISH 5.5-4 12000 7.2 " " GRISH 4.2-3 16800 5.4 " " GRISH 4.5-4 15000 8.2 OK " COX 6-3 11800 9.6 " " COX 6-4 11800 9.0 critical 7-2 WOOD [custom] 10300 7.8 OK 5.5-2 APC 15800 8.2 good needle 5.7-3 APC 14300 9.2 OK needle 5-3 COX [ depitched ] 17500 7.0 easy to needle I know that any other hotter reeds would blow these numbers away, and move the smaller props up on output. I don't have any gray props to test, but it's good to know that a 6-3 COX black prop is the champ of the "bench press competition". In actual practice when I'm flying reed combat it works better to cut down to 5.5 to keep the Rs up during manuevers. |
Propjobbill,
Thanks for the information on how to get more performance on these engines. I have another question, I have been hearing about Turbo Plugs, what the heck are they? I use Galbreath heads , works OK if it is not to cold out, in the cold I have to switch back to Cox. Might be the fact that the galbreath plug I am using is 10 years old and doesn't hold the heat like a newer one. Have you ever messed with the re-porting on one of these? I might try to ad the flutes in the ports like what was used in the Killer Bee engine to see if I can pick up some more rpms. Don't know how to do that yet but...... Thanks, Pat |
I don’t know much about different plugs or heads. I have read different places that nelson plugs get about 1,000 more rpm. Also all the guys in the know claim that you can get more rpm by changing the number of head gaskets, usually from 1 = 4. Running more head gaskets decreases the compression, and also changes the timing of the engine. If it were possible to change the heat range of the plug this also changes the rpm. Changing the heat range also changes the timing. From what I understand the only way to know which works best is to experiment, and keep a record of the results. Lowering the compression helps as you increase the percentage of nitro, or at least that's what they say.
I am new at making modifications to Cox engines, but when spring gets here I am going to try some of these tricks and see what happens. If I have any success I will share my knowledge. I have no intentions of competing in any way. I simply like the extra power, because it lets me fly a little better. |
A couple of things to consider:
As you increase the venturi size, you decrease the engine's ability to suck fuel. That may be important on some installations. To overcome this you may have to use a pressurized fuel system. You can also increase suction somewhat by upping the venturi velocity through increasing RPM via a smaller diameter or pitched prop...whichever will work on your plane. Varying compression (via shims), plug heat range, prop load, and nitro content all contribute to combustion timing. The higher power per cubic inch you get, the more critical these things become to increase performance...until you reach a point of mechanical failure. With knowledge gained, however, you might know when you need to change prop size or plug for a particular fuel you are using, etc. ...Trial and error also works... ;) George |
Thanks for all of you input. Does anyone know what Tim Wiltse did to get his motors to run so well? |
I don't know his secret tricks but the Stage 3 Skyline engine I bought from him runs awesome. Very smooth and consistent for a reedie once it finally broke in. I know he lightened the piston and modified the venturi shape a bit. Has one of his custom turbo plug heads on it as well. Piston/cylinder fit feels very tight and it has a nice pop to it when you turn it over by hand. I've never disassembled mine and don't feel the need to do so yet since it doesn't have much time on it. He was making neat stuff. Hope he comes back around in time.
Thanks Tee Bee,
I ordered a stage 3 last fall and I guess it was a little to late. The pop you are talking about is probably taper in the cylinder. I bought a Kustom Kraftsman Tee Dee back in the eighties and it had that same feel. I wish I new how to do that, that is probably one of the big fixes/mods that make these thing sing. One of these days I will figure it out. I have bought a few dozen Sure Starts so I can afford some learning curve (ruin) modifications. Will work with an old timer in the machine tool busines to see if he can figure it out. I hope Mr. Wiltse gets back in the game also. Thanks, Pat |
just received cox christen eagle ep and also received e-mail that col .o49 engine had shipped today
1 Attachment(s)
You may like my idea of making a carb. for cox .049 sure start. It looks vary simple, yet effective (pictures will tell the whole story)
Nice job, but I think there is an inherent problem with a carburator on a reed engine?
The reed only closes due to a higher pressure in the crank and that''s fine at full throttle but near idle the restriction of the carburator gives an underpressure. This would be ok if it stayed constant but as the reed is shut (do to a higher pressure in the crank) the throttle is still "leaking" and the pressure will continue to rise on the wrong side of the reed... [:'(] I think the TeeDee would be much better suited for a carburator, please feel free to prove me wrong. :) |
ORIGINAL: Mr Cox Nice job, but I think there is an inherent problem with a carburator on a reed engine? The reed only closes due to a higher pressure in the crank and that''''s fine at full throttle but near idle the restriction of the carburator gives an underpressure. This would be ok if it stayed constant but as the reed is shut (do to a higher pressure in the crank) the throttle is still "leaking" and the pressure will continue to rise on the wrong side of the reed... [:''(] I think the TeeDee would be much better suited for a carburator, please feel free to prove me wrong. :) |
I simply don''t think that the reed is able to operate and shut the inlet like it should, since it is only relying on pressure differences to do so.
With that thinking, the reed should work just fine. The pressures inside the engine shouldn''t vary much with RPM, just the frequency of the pulses. Seems I heard somewhere that the limiting factor in a reedie''s performance is the reed...tends to float at high RPM. I''m betting the reed performs better at lower RPM - more time to overcome inertia.
The reed valve will be less effective when the throttle is closed down and the RPM and pressure differential are lowered,
which I think will cause a leaning out of fuel mixture. So you probably wont be able to acheive as low an idle speed as with a rotary valve. You may have to richen overall mixture. But the concept does appear to work, especially with the choke tube throttle which inherently increases fuel mixture as you close down the choke valve. |
It is not the rpm itself that I'm after, it is the low pressure caused by the restrictive throttle that I think cases problems for the reed.
Maybe I'm looking for a solution to a problem that''s not there, but there is something about the reeds and a throttle that is not working well. |
There''s youtube videos of throttle-converted SS''s that idle beautifully. Of course, the QB didn''t idle so well, but I think that was just ''cuz of the lousy carb it had.
The proof will be in the numbers when he runs it...then we''ll all know. |
propjobbill , are you saying that you reset the piston on a brand new engine? How does give you more performance and why do you have to do it on a new engine? Thanks.
ORIGINAL: rc2007 propjobbill , are you saying that you reset the piston on a brand new engine? How does give you more performance and why do you have to do it on a new engine? Thanks. I imagine propjobbill does it for the same reason I do. I have found the fit on new Cox engines variable. Aside from any effect on performance a sloppy rod/piston fit will accelerate wear. jess |
That''s exactly, I mean exactly what I''ve done! I used an AP .061 carb though. I have been meaning to post some pics. My wife and I are in our newly constructed home now, I just need to get the things from my mother-in-laws house over to this one. I may even post some pics of our new home; I''m very proud of it.
I don''t have any problems at all with idle, transition or the likes, however, it does have a rather high idle. Who cares though, I now don''t have an .049 screaming constantly. |
ORIGINAL: jessiej ORIGINAL: rc2007 propjobbill , are you saying that you reset the piston on a brand new engine? How does give you more performance and why do you have to do it on a new engine? Thanks. I imagine propjobbill does it for the same reason I do. I have found the fit on new Cox engines variable. Aside from any effect on performance a sloppy rod/piston fit will accelerate wear. jess |
I feel fortunate so many knowledgable .049 folks are around. After fussing for days with a formerly great running Black Widow that had been put away and permitted to gunk up; I ordered a couple of the Sure Starts even though a good many threads/posts had me wondering about how good they''d be.
Well, I''ve run-in two of them now and have to same I am impressed. Seems like they''d properly headspace just from running. At any rate, I just removed the stack off the back and bolted them to a Slickmount. They run for 11-12 minutes on a tank while they''re rich and breaking in. You can see the grey residue running off the block as they wear in and then clear up at the same time they smoothout. Who knows how long one will last but as smooth as they are going I have to wonder what the clues are that a piston reset needs to be performed? Genuinely curious, Clay |
ORIGINAL: Clay Walters ...Who knows how long one will last but as smooth as they are going I have to wonder what the clues are that a piston reset needs to be performed? Genuinely curious, Clay With the backplate off, turn the prop until the piston is partway up and hold it there until gas escapes past the piston and it will hold that position. Now VERY GENTLY rock the prop just enough to see movement in the crankshaft but not move the piston. There will be a little slop on the lower end at the crankpin. Any extra slop of the conrod moving without the piston moving is ball-socket slop. You can see it if you look up into the bottom of the piston. Another way is to remove the piston and, holding it so you can see the bottom, push and pull on the conrod. Very slight looseness is tolerable. Ideal is little or no slop, without binding. The faster you run the engine, the closer the fits need to be. In all honesty, I ran Cox engines for many years of sport flying without owning a reset tool. But then it was sport flying with no more than 25% nitro, ~22% oil, and usually a large (6x3) prop. George |
Thanks George. I recently purchase a 5.5-? prop since it was the only .049 prop the shop had -but haven't tried it yet. (That's how it was actually labeled!)
Still using a couple of 6-3 windsor props I have from 20+ years back and have started looking to see who carries the small stuff. Dissappointed to see it start drying up and suspect a revival of interest at some point. (Seems like that's how it always goes) In the meantime, now that my interest has been revived I need to locate sources. Unless you think the 5.5 (don't recall pitch) will introduce problems I guess the 12,000 rpm range gives me minimum exposure? Regards, Clay |
There is a member here ( Skaliwag ) who is a Cox Guru and has a website with Cox engines and parts and lots of nice kits and hardware etc for 1/2a and small planes. He has been a big help to me. His website is: www.selecthobbies.com
ORIGINAL: air-madness That's exactly, I mean exactly what I've done! I used an AP .061 carb though. I have been meaning to post some pics. My wife and I are in our newly constructed home now, I just need to get the things from my mother-in-laws house over to this one. I may even post some pics of our new home I'm very proud of it. I don't have any problems at all with idle, transition or the likes, however, it does have a rather high idle. Who cares though, I now don't have an .049 screaming constantly. it has slightly slow transition. I would like to see, how your AP carb. responses. |
