NEED GLOWPLUG IGNITOR
1 Attachment(s)
I need a glowplug ignitor for my 1/2A scales. Pictured below is a Wasp engine I have installed and the ignitor I have.
As you can see in the pic there is a ringed gap around the glowplug and a normal size ignitor will not clip on and lock. Any ideas? |
RE: NEED GLOWPLUG IGNITOR
I used to fly some planes with cowled engines, and only a small hole above the plug center contact was open. I used a pair of alligator clips, insulated, one to grab the plug center conductor, one to grab the protruding needle valve - it worked fine.
I bought a clothespin style plug clip a while back that had alligator clips on the other end of the wire for connecting to a battery from a control line supplier. I have a Deans 2-pin connector on the output of my plug driver, and after cutting the wires in two and putting on a couple of deans male plugs, I now have both a clothespin type, and a pair of alligator clips that will work with my plug driver.. I'm not a real big fan of those "hang the battery on the plug" glow plug drivers. Lately I've been using a radio south driver, but I just got a new 2V battery for my old trusty Globee "fireplug" |
I have the same engine and glo starter. It won't lock onto a wasp .061 you either need to have another person to hold it on the plug while you start it, or you could get one of these:
http://www3.towerhobbies.com/cgi-bin...?&I=LXFU06&P=0 Dave has a similar or maybe the same thing as it hooked up to his rechargable glow battery, and it seems to work great! -Bill |
I found these http://www3.towerhobbies.com/cgi-bin...?&I=LXL338&P=7 and I was wondering if I could connect them to my charger and the engine as suggested by fizzwater2?
If yes, which color wire goes to the glowplug and which to the needle valve? |
1 Attachment(s)
This is what you want. It clips onto your 1/2A glowhead and plugs into your Ni-Starter:
http://www3.towerhobbies.com/cgi-bin...?&I=LXBWL9&P=7 They work as good as anything else I've tried. I put heavier wire on mine and a Deans connector. I use two Sanyo 1300mah SC cells in parallel and it lasts all day between charges. David |
Perhaps I will, but I am curious as to whether these would work
http://www3.towerhobbies.com/cgi-bin...?&I=LXL338&P=7 But as I asked which wire goes to plug and which to needlevalve? |
doesn't make any difference which wire goes to which one, the glow plug doesn't care.
I guess that would work, but it's a lot more complicated than just using the clip that's designed to fit a 1/2A glowhead.
David |
ORIGINAL: rainedave I guess that would work, but it's a lot more complicated than just using the clip that's designed to fit a 1/2A glowhead. David -Bill |
I use the same one David has, but I left the adapter on. I can then use the same ignitor and battery for other engines.
I thought that Radio Shack designed their small alligator clips just for us 1/2A guys.
| All times are GMT -8. The time now is 07:45 AM. |
