RE: my cub flies a lil funny
thanks for all the good imput guys. i was thinking about the thrust line being off and i thought i would make it roll to the left from the torq of the engine, so ive kinda ruled that one out. i know the engine is too big so i cut the max throttle down to 75%(left it a lil high to be on the safe side) and i still only use about half and thats on take off. i was looking at the wings and i would say the ailerons are sittilng at a 30* from neutral and i was thinking that was kinda alot for trim, i was thought that trim was only ment for a couple of clicks and after that is a lil drastic for trim and thats when you should check to make sure everything is neutral and i have already done that. im going to check for wing warp when i get home and let you guys know what i find out.
lnewqban,
are you saying i just might need to add more trim to the rudder? from what ive read the cubs are a lil tricky to fly so it just might be me and need someone that has a lot more experience to fly it.
