RCU Forums - View Single Post - ASP FS61AR
Thread: ASP FS61AR
Old 09-15-2010 | 01:42 AM
sandal
Default RE: ASP FS61AR
jeffie8696; Thank you for the suggestions! Cam timing is correct, and the glow plug is an OS F. The valves might be on the loose side, but I'm not sure. A .0015" feeler gauge will pass freely, a .004" will pass with some friction. I set the valve clearances yesterday before I ran the engine. The valves seem to seal better after I adjusted them.
I'll try a fresh bottle of fuel and see if that changes anything.
