RE: Let's See Your SlowPokes
ED,
I thought the Poke .40 already had ailerons or is this a different version? I built a Slowpoke .10 wing like a .40 Poke. See my post above of the Poke with the AT-6 scheme. I'll post building pics below. The building process is the same as the .40 excepton a smaller scale. I downloaded the .40 size Poke manual and blueprints from online and looked at them, and built according to the manual. I used the last four full wing ribs. The two outer ones were left whole and the inner ones were cut with the aft side where the longitudinal stringers were. I filled in-between the stringers with balsa so I had a place to mount the hinges. I used the cut off pieces of wing rib and made a few more to make the ailerons. Essentially, they are the wing ribs ends glued to a stick of balsa and covered with 1/16" sheet.
The dimensions of the ailerons are approximately 11.5" X 2.5" Of course, your's may be a little different size because you will be building a full .40 size.
As far as performance, it flies great. Greatroll rate. I made several other mods that I won't get into here unless yo want to know.
