RCU Forums - View Single Post - Digital Servo Setup
Old 09-15-2010 | 09:06 AM
BarracudaHockey's Avatar
BarracudaHockey
Default RE: Digital Servo Setup
Are they both knew or could they have been programmed by someone else before?
Have you checked the servo monitor screen if you're using two channels to see if the indicators are moving the same amount?
Try swapping the servos and seeing if the problem follows the servo or stays where it is.
