RE: engine temps
So are you saying that the European engines that use low or no nitro are not in danger of over heating from the alcohol flame? That the danger is from friction. Over heating in my definition is where the high temperature allows systems to fail. In the case of our engine the seal between the piston, cylinder, ring or the film strength on the rod journals. Over temp is not limited to changing of the material characteristics (size, grain structure or oil film strength).
