RCU Forums - View Single Post - ar700 rx dx7 tx help
Old 09-15-2010 | 11:15 AM
417mack
Default RE: ar700 rx dx7 tx help
 I had a little time this morning to investigate. I almost do not want to post what I found but will. This was a servo problem, the screw that holds the pushrod was to shors so was only applying moderate pressure and was slipping under the vibration of the engine, replaced the sceew with a longer one and now works fine. I thank all of you again for the spot on advice.
