Fuel draw
I think consideration must be given to the fact that when the rpm are pulled down at full throttle the airflow velocity through the carb is reduced which in turn reduces fuel draw causing the sudden fall off in power and subsequent quitting. A pump of some sort would cure this without altering the power characteristics.
