RE: norvel 049 and 061 comeback??
Devious Dave- Totally agree, If you look at the products Davis has produced over the years QUALITY RULES, besides the head for the coxes, as we know his Killer crank for the Coxes solved the issue for broken cranks for the reed valve Coxes run as glow or diesel, a piston reset tool to take up the slop in the rod/piston assembly, even cleaning brushs
It goes further if you check the Davis diesel site you will see the "sister site" Marbo skin care, again quality and results, if not better than the rest would not exsist martin
