RE: RedWing MX2 Build
Nice Job on the build! Your a lot more meticulous than me, I just used Sulivan threaded rod for the whole linkage... Mine is a tad shorter than yours because the carb is in the back of the engine.<div>
</div><div>did you disco the spring from the throttle? have you ever used one of the HS 82MG's for the throttle on one of these larger planes? The reason why I ask is this is a bigger plane with more vibes than the small electrics and nitros that its intended for. There was a thread I was following about them on profiles. Once I find it I'll post the link.</div>
