RCU Forums - View Single Post - Sig Kadet LT .25
Old 09-17-2010 | 04:43 PM
  #70
QJ
Default RE: Sig Kadet LT .25
Looks really good biff - fast work.Keep us involved.Have you run the engine yet?
I have covered the fin now and it looks great. I plan to put white on top of the tailplane and orange underneath. The white covering is semi-transparent so you don't see much through it.
EDIT:I did the elevator this morning and got too much air stuck inside the air pockets. I had to use heat to un-stick a part of the edge to get a blade in and let the air out. Quite stressful. Looks ok now though. I was so tempted just to stick a needle in it but I guess that would be a bad idea with so much tension in the stretched covering.
Can anybody advise: should I use dope underneath fuelproof paint, or just paint directly onto wood (balsa/ply)? The SIG manual recommends to paint straight onto the wood - is this right?
QJ<br type="_moz" />
ID:	1502544   Click image for larger version
