RCU Forums - View Single Post - SIG Ryan STA special kit by Maxy Hester
Old 09-17-2010 | 05:12 PM
jwharkinz's Avatar
jwharkinz
Default RE: SIG Ryan STA special kit by Maxy Hester
I have started to work on the wing at this point in construction and the theme is going in the direction of restoring and modifying and old
aircraft to perform a lot like a new high performance plane. I am toying with the idea of completing this in an unfinished polished aluminum
fuse and aluminum colored wing and tail surfaces. This will require a serious amount of custom chrome plating to all the plastic which I
am currently looking into, this is now possible these days so it might be worth the cost if it can be done well.
The wing is going to look more like something from a newer build; I chose this to add rigidity and help alleviate the possibility of folding
during high G maneuvers, the tail structures are going to get similar treatment with the increase in hard wood to help maintain the original
appearance.
ID:	1502556   Click image for larger version
ID:	1502557   Click image for larger version
ID:	1502558   Click image for larger version
ID:	1502559   Click image for larger version
ID:	1502560   Click image for larger version
ID:	1502561   Click image for larger version
ID:	1502562   Click image for larger version
ID:	1502564   Click image for larger version
ID:	1502565   Click image for larger version
ID:	1502566   Click image for larger version
