RE: servo reversing y-harness
Airbusdrv is correct never use a reversing Y on a flight control if you don't have to....if you have a computerized transmitter you should be able to mix elevator to another channel.
Why not a reversing Y? Because they can fail easier than a regular Y and it will cost you an airplane....
It would be better to flip the servo horn over if you have the room
