RCU Forums - View Single Post - reciever antenna solder or replace?
Old 09-18-2010 | 12:25 PM
SyCo_VeNoM's Avatar
SyCo_VeNoM
Default RE: reciever antenna solder or replace?
ORIGINAL: rabbit1
hey when a receivers antenna wire is cut, will simply soldering it back together work or do you have to take apart the receiver and start fresh?
If its AM or FM I'll agree with alvinl just solder it, the most that will happen is you lose a few feet(probably more like half a foot) of range. If you have any use some liquid electrical tape, or a small piece of heat shrink tube to cover the solder joint so you don't hit any metal with it by accident.
2.4ghz replace seeing the antenna is actually the little bit of silver at the tip, the wire prior to it is shielded, and will not function properly is the shielding is broken.
