RCU Forums - View Single Post - DX6I Tx Functions
Old 09-19-2010 | 03:21 PM
kiwibob72
Default RE: DX6I Tx Functions
ORIGINAL: crmamx
I am fairly new to the sport and have just bought a Spectrum DX6I to replace my DX5E. Could someone please explain the following functions to me....when and why I might want to use them and roughly what the initial settings might be:
Travel adjust
Servo monitor
Wing tail mix
Dual rate combo
Travel adjustment
Sub trim
Programmable mixing & Trim include
Differential aileron mixing
For what I can offer :
DUAL RATE COMBO - you can allocate all the Ali, Elevator and rudder Dual rates to one single switch instead of each single switch on the TX (it allows you to turn them all on at once for when your planes setup, and you want to fly at high speed)
SUB TRIM - a "permanent" centering tool for your servo, it is adjusted in the programming when setting up (to ensure your servo arms are centered), and will also allow you to set as default any adjustment to a given servo should you require to remove any trim down the line - the one on your tx face should only be a setup tool, and should be centered once your sub trim is setup correctly
