RCU Forums - View Single Post - SAP 180 (Syssa Performance)
Old 09-19-2010 | 05:08 PM
  #1300
MTK
Default RE: SAP 180 (Syssa Performance)
ORIGINAL: cmoulder
Matt,
Thanks for the tips.
After trimming and sanding my panels weigh 41.6, 41.8, 35.6(!), and 41.1 grams, so the stuff supplied by Mark Hunt with the ''pro'' kit is definitely worthy of the project.
I know there are several different theories about gluing the sheeting together (or not gluing at all), but I decided to follow the suggestion of Clay at The Balsa Store and glue them with plain ol' Elmers White glue. Worked GREAT! Easy to apply using one of those little plastic applicators (that looks like a pipette with a squeeze bulb on the end), easy to wipe off excess with a paper towel and easy to sand. The panels all came out flat with zero buckling even before sanding.
In any event, weather is superb again (like yesterday, ugh!) and family obligations are met, so I am going to fly the hard-mounted SAP today for the first time.
Good!! Elmer's works fine...used it for years. In fact the only thing I probably have not tried is not gluing the sheets together. Expecting Pro Bond to foam up into the joints, in my mind, would be too much expectation. It works for some to which I say, Great!
I don't use Pro Bond...I'm not that fast in my setup of skins and foam. Points is, there are a couple options all resulting in good, strong and light wing panels.
I actually flew Temptress today. We had excellent conditions so it was great to be out and flying. The SAP was 1 flip starts all day. I flew at the New Milford field which is mostly large birds with honking DA150s. What a noise footprint difference between the extremely quiet piped SAP and the larger birds.
