RE: GP Super Stearman
Well you guys, Did my maiden. What a rock solid airplane ! I chose to install a set of Williams Bros 4 1/2 inch classic tires for training purposes. Some of you were saying that three point landings should not be attempted because of bounce. It may be with the stock tires but I've had no problems and this is on an asphalt runway. OS 1.20 gives it pretty much scale power at 4500 feet elevation. Because it lands smooth, I also switched to the second landing gear with wheel pants [ but yes, I installed the Dubro 4 inch inflatable tires just to be safe]. Well worth the cost this ARF is. Seeya, MM
