RCU Forums - View Single Post - SIG Ryan STA special kit by Maxy Hester
Old 09-19-2010 | 08:23 PM
jwharkinz's Avatar
jwharkinz
Default RE: SIG Ryan STA special kit by Maxy Hester
The Flite Metal Looks good, I'm going to look into this method for sure. thanks for the heads up.
Believe it or not the metal tube is 5/32 OD and an old as heck drill bit held in with nothing more
than fitting in tight, just got luck I guess. For the clean hole what I did was start with very
light pressure then let the bit do the cutting, what the pic doesn’t show is the exit, not as neat but it will
have a scrap piece of balsa to enclose the hole.
