RCU Forums - View Single Post - DLE30!
Thread: DLE30!
Old 09-20-2010 | 09:27 AM
  #3877
WCB
Default RE: NEW DLE30!
Let me run this by you guys and see what you think. My DLE30 V2 runs great at all attitudes, however, when I do a vertical figure 8 and come out on the last part (bottom) of the 8 from being inverted back to level the engine sputters and almost dies every time. It only does it at the exact same spot in that maneuver every time and it does it no matter what the throttle setting is. I put the plane in every extreme positive/ negative G maneuver I know how to do plus inverted flight, outside loops with snaps at the top..you name it and it doesn't miss a lick. I checked the clunk and there are no problems with the tank. The engine is on a CG Sukhoi and it has about 1 gal of gas through it, Xoar 19x8 prop, Pennzoil at 32:1.
I can't figure out why it only does it in that one place in that figure 8 and nowhere else.
Any ideas?
Bill
