RCU Forums - View Single Post - Robart Hinge Replacement - Getting the old out?
Old 09-20-2010 | 11:30 AM
Chad Veich
My Feedback: (60)
Default RE: Robart Hinge Replacement - Getting the old out?
I drill them out with a piece of sharpened brass tube chucked up in a drill. Then, I go up to the next size brass tube and use that to cut a dowel from a block of balsa which will then be a perfect fit for the hole left over after removing the hinge. Works perfectly every time!
