RCU Forums - View Single Post - Open discussion about the glow engine's carb
Old 09-20-2010 | 09:36 PM
earlwb's Avatar
earlwb
Default RE: Open discussion about the glow engine's carb
Here is one of the ASP 61 four cycle engines I messed with previously. In hindsight I think it was centering the needle valve more than sealing the threads up. But the little piece of fuel tubing worked and the engines ran fine afterwards.
But on the remote needle valves it may have helped with two problems, a needle valve that wasn't centered and a air leak as well.
Before
After with the tubing in place.
